Wheel split in half due to overinflation.
Overinflated tire explosion - GIF
Popping a deformed tire - GIF
Tire blowout demonstration - GIF
Mounting tires with fire - GIF
Overinflated tire launches man into the air - GIF
nova_robotics (Dec 30, 2023), Ralphxyz (Jan 1, 2024)
I would say that rubber band tire cracked the rim while being driven maybe over inflated maybe not but a pothole could have caused a crack which immediately would cause the tire to lose inflation. the crack would have continued all the way around as the vehicle was being driven. The side wall on those tires is so small it is hard to know if you have a flat. nova_robotics had a point the only thing holding that rim to the tire was the bead itself. The crack may not have been all the way around until the bed breaker pushed against the rim.
My take on this guys is that he forgot to pull the valve core on the valve stem and tried to unseat the bead of the tire without deflating the tire first. Weak rim? Yes but looking closely at the machine and tire at the moment of separation looks like the tire forced the rim apart. Compressed by the bead breaker arm/tool.
My though... for what ot's worth.
Doug
Doug Dry Creek Smithing
