Results 1 to 10 of 14
Thread: Why flat belts need crowned pulleys.
  1. #6
    Marion, Iowa
    metric_taper's Tools
    I am not surprised that you had problems with the convex crown on the work wheel. Terrible idea.
    You did not describe your machine but I am guessing that you have 3+ pulleys. 1 on the motor, at least one idler and the work pulley. I would put the crown on the motor pulley.
    The only reason that I know that would require a concave pulley is if one or more pulley axes is/are misaligned causing a tendency to throw the belt one way, compensated by the concave pulley trying to throw it the other way, hence compensating. On wide pulleys such as on a belt grinder it only takes a tiny axes misalignment to force the belt one way. In fact some machines do not have crowned wheels, instead there is a misalignment adjustment with which you can use to make the belt track true. The misalignment works like one half of a crowned pulley and obeys the same rules.
    Glad that you have found a workable solution.
    PS. You mentioned the problem got worse when warmed up. Expansion somewhere in the system may be causing any slight misalignment to change. 13" wide belts only need a tiny change to act differently.
    What gets hot is the sanding belt, and elongates just enough to run away.
    However, by having the idler with a concave crown, the belt can only get so long, and it is captured by this trough.
    This is a two roller system;
Name:	view of machine.jpg
    Top roller edge showing duct tape. This is a stable configuration as the bottom roller has no crown. A convexed crown in this machine was unstable.
Name:	view of roller edge.jpg
    Bottom view showing driver roller, opposite side of machine has 2HP motor with direct connection to this roller.
  2. The Following User Says Thank You to metric_taper For This Useful Post:
    tonyfoale (Jan 27, 2021)
