Thread: Wood lathe drive center
    France, Brittany !
    Christophe Mineau's Tools
    Here is a small diameter drive center I have made for my wood lathe, for driving small diameter pieces with a small and not too deep print in the wood.
    It's made with a standard morse taper MT2 cone, sold for holding a drill chuck.
    I had to drill at its end, and it's hardened steel. I managed to drill an 8 mm hole using a carbide bit made for drilling glass and tiles. I did that on the metal lathe, with lubricant.
    Then I adapted a little toothed crown I found in one of those kits sold for fixing tap seat issues.
    This is the idea, these crowns are ideal for driving the wood, and they are not too aggressive but hold it very well.
    The center has a threaded hole, you can even change them as you wish, as there are several sizes.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 2 Users Say Thank You to Christophe Mineau For This Useful Post:
    kbalch (Jan 20, 2015), PJs (Oct 1, 2015)
    Very nice, Christophe!
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Wood Lathe Drive Center to our Wood Lathes and Workholding categories, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Nice work.
    Doc
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Christophe,
    Very nice adaptation (mashup) with your choice of a faucet seat tool. I am now encourage to modify my hardened morse taper MT2 adaptors for other purposes using your drilling advice.
    Thanks for sharing, Paul
  7. The Following User Says Thank You to Paul Jones For This Useful Post:
    Christophe Mineau (Jan 22, 2015)
    France, Brittany !
    Thanks Paul,
    It's my good friend Bob Strawn who actually showed here how he drilled HSS with a concrete drill bit. as I had one of these glass carbide bits, I gave it a try. The cutting edge is better than a concrete bit, though it may be more fragile. But with lubricant and not too fast speed, it did the job.
    Cheers !
    Christophe
  9. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    PJs (Oct 1, 2015)
