Results 1 to 10 of 10
Thread: Work Holding with Sacrificial Nut and Bolt
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Very simple work holding with a sacrificial nut and bolt. When silver soldering you don’t want your best engineers clamps in the path of a blow torch. Also, you don’t want the thermal mass of a large clamp.
    I often have this problem and resort to a piece of wire that wraps around and is twisted tight. Or I try to balance a fire brick on top to hold it all together. The other option is to use a mechanical joint as well such as a rivet. However, sometimes these are not great options for other reasons.
    Even after heating this to 650°C the bolts came apart very easily
    I know this is a bit mundane, but sometimes we all need a prod to get us thinking outside of the box.
  2. The Following 13 Users Say Thank You to editor@glue-it.com For This Useful Post:
    bigtrev8xl (May 7, 2021), emu roo (Jun 13, 2025), Marnat3 (May 5, 2021), mklotz (May 5, 2021), Moby Duck (May 6, 2021), mr mikey (Aug 17, 2023), Paul Jones (May 11, 2021), rgsparber (May 5, 2021), sacco1 (May 6, 2021), Scotsman Hosie (May 10, 2021), Scotty1 (May 5, 2021), techcollect (May 10, 2021), winmac (Jul 21, 2023)
    Mundane or not, it's an excellent technique
    When constructing model engine "solderments", it's not unusual to hold the parts together with brass screws for soldering and then mill away the exposed part of the screw after soldering. Done carefully the join is undetectable.
  4. The Following 6 Users Say Thank You to mklotz For This Useful Post:
    editor@glue-it.com (May 7, 2021), emu roo (Jun 13, 2025), mcthistle007 (May 10, 2021), Moby Duck (May 6, 2021), Paul Jones (May 11, 2021), Scotsman Hosie (May 10, 2021)
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    I don't get it, what are you soldering? (Sometimes the obvious goes right over my head.)
  6. The Following User Says Thank You to katy For This Useful Post:
    Ralphxyz (May 9, 2021)
    Thanks editor@glue-it.com! We've added your Silver Soldering Clamp to our Clamps category,
    as well as to your builder page: editor@glue-it.com's Homemade Tools. Your receipt:
    Apr 2017
    UK
    Quote Originally Posted by katy View Post
    Hi Katy, this is a small brass dish made from flat sheet and I'm soldering the flange on the sides together, plus I'm soldering the base in. The tube is for a supply of liquid into the dish. The bolts are temporarily holding the flange together and thus clamping and locking the base plate as well whilst I silver solder (650°C). Hope this helps
  9. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    wombat50 (Aug 17, 2023)
  10. #6
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Thanks, that makes sense, still smilin', Ken
  11. #7
    Supporting Member wombat50's Avatar
    Jan 2021
    Canberra, Australia
    Yes, I was also wondering what was actually being soldered?
  12. #8
    Jan 2021
    Canberra, Australia
    Sorry, only saw your concise explanation after posting my question 🤗
  13. #9
    Apr 2017
    UK
    Quote Originally Posted by wombat50 View Post
    Sorry, only saw your concise explanation after posting my question ��
    ah, sometimes pictures are not 1000 words
  14. #10
    Quote Originally Posted by editor@glue-it.com View Post
    How true! A picture of the word "word" would only be worth a single word.
