Thread: work table forming break
    This is probably more of a tool tip than a tool. What do you do when you need to make a 90° bend in a 8ft sheet of 14ga steel and your break will only do 7ft widths.
    What I did was to clamp the sheet down to my tilting worktable using an angle iron and the stick of rect tubing as a stiffener.
    then Ironed the bend in using a 2" dead blow hammer,
    I clamped a discarded part to the edge of the sheet and pulled it down with ratchet straps while ironing in the bend
    close enough to work with
    baja (Apr 15, 2023)
    Thanks Frank S! We've added your Work Table Brake to our Brakes and Presses category,
