Results 1 to 8 of 8
Thread: WWI portable saw - GIF
    emu roo (Aug 15, 2025), nova_robotics (Aug 16, 2025), odd one (Aug 23, 2025)
    hemmjo's Tools
    I wonder if that cuts both ways, like a two man cross cut saw?
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    It would have to, otherwise you would have to pull it out and reset after each pull/stroke.
    hemmjo's Tools
    Quote Originally Posted by odd one View Post
    I hope it would, but would not have to take it out to pull it back. It just would not cut on the back stroke, like a regular hand saw.
    Apr 2020
    WNC
    odd one's Tools
    True, had not thought about that. I have a modern version with ropes on it that you throw a weighted bag up and over the branch and pull it into position. Works good but really needs two people as only one causes the saw to be in contact with too much of the branch creating too much resistance. Mine is like a chainsaw blade and has teeth facing both directions. It is a bear if the chain gets pinched way up in a tree though.
    hemmjo's Tools
    I have seen those "toss over the limb" saws. Seems to me, as you mention, it would be very easy to get stuck if it cuts both directions and it is wrapped 1/2 way around the limb. Both handles dropping down to you. Also, you would be right in the line of fire for the falling chips and the branch when it breaks off.
  8. #7
    Apr 2020
    WNC
    odd one's Tools
    When we have used it, we found that a good 60deg works...wider if you can get it...which also puts you out of the fall line of the branch and chips. It has worked great in some situations and been a total PITA in others....but what can you do when you are too cheap to rent a bucket lift and too old/smart to climb the tree. I have 14 - 80' older pines along my drive that need to come down before a storm takes them down on my house or my neighbors. I'm dreading to see how much that is going to cost me.
  9. #8
    hemmjo's Tools
    Are there any loggers in the area? They may come, take them down, take the big logs and leave you with the branches and tops. Rent a chipper make yourself a bunch of mulch.
  10. The Following User Says Thank You to hemmjo For This Useful Post:
