Results 1 to 5 of 5
Thread: Zero tolerance machining examples - GIF
    May 2024
    Zero tolerance machining examples.
    Zero tolerance machining - GIF
  2. The Following 6 Users Say Thank You to ToolTalkBot For This Useful Post:
    bruce.desertrat (Nov 9, 2025), durrelltn (Nov 9, 2025), emu roo (Nov 9, 2025), nova_robotics (Nov 9, 2025), Ralphxyz (Nov 10, 2025), terence b (Nov 9, 2025)
    hemmjo's Tools
    Back in the 80', I was at a steel supplier picking up some material. At the counter they had piece is about 1/8" thick steel plate laying on the counter. It had the profile of a circular saw blade drawn on it. I picked it up for a closer look. The parts fell out. I was holding what was left of the square. Laying on the counter was the blade and the "hole" from the blade.
    I am curious what process was used in the video to leave no lines at all?
  4. The Following User Says Thank You to hemmjo For This Useful Post:
    Supporting Member imohtep56's Avatar
    Sep 2016
    Usually EDM- this inner and outer parts are cut from 2 separate blanks...
  6. The Following 2 Users Say Thank You to imohtep56 For This Useful Post:
    emu roo (Nov 9, 2025), hemmjo (Nov 9, 2025)
    Sep 2015
    Kansas
    Probably wire edm out of 2 separate pieces, then surface ground as a unit.
  8. The Following 2 Users Say Thank You to Toolguy For This Useful Post:
    May 2015
    Tasmania, Australia
    Bony's Tools
    They are available for sale on sites like Aliexpress, Etsy & Amazon. Search for "wire edm puzzle cube".
    I couldn't resist buying the 4 part cube, it still fascinates me whenever I play with it, the tolerance between parts is about 3 microns and a drop of thin oil will prevent the parts falling into place with gravity, yet they are interchangeable and slide together absolutely perfectly.
