Thread: Zvezda M503 maritime radial diesel engine - photos
  2. The Following 8 Users Say Thank You to Altair For This Useful Post:
    baja (Nov 13, 2020), freddo4 (Nov 15, 2020), jimfols (Nov 14, 2020), KustomsbyKent (Nov 13, 2020), mwmkravchenko (Nov 12, 2020), nova_robotics (Nov 12, 2020), Rangi (Nov 14, 2020), rdarrylb (Nov 12, 2020)
    trigger's Avatar
    Jun 2018
    Internal lubrication must have been tough to design....
    Supporting Member jimfols's Avatar
    Sep 2015
    Ontario Calif USA
    That is quite a Lump.
    oldmachinepress.com/2016/09/05/yakovlev-m-501...
    Sep 05, 2016 · Its compression ratio was 13 to 1. The M503’s maximum output was 3,943 hp (2,940 kW) at 2,200 rpm, and its maximum continuous output was 3,252 hp (2,425 kW) at the same rpm. The engine was 12.14 ft (3.70 m) long, 5.12 ft (1.56 m) in diameter, and had a dry weight of 12,015 lb (5,450 kg).
    Jim
