Results 1 to 7 of 7
Thread: [Woodwind instrument making] Ball post drilling fixture
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I recently showed a tool designed for turning small balls. It is explained here :
    http://www.homemadetools.net/forum/m...946#post109053
    This tool is especially useful for turning ball posts, which are the small pivots used to support the rod of a key on a woodwind musical instrument.
    Here is a batch of nickel silver ball post blanks : (they are quite small, the ball is 4.5 mm in diameter.)
    For supporting the rod, which is actually a long 2mm diameter screw, one ball must be drilled through, 2mm diameter, and the other ball must be tapped M2, so drilled 1.5mm.
    It is quite challenging drilling such small holes through a ball shaped piece, and it is quite critical to keep well centered.
    So I imagined this little fixture for that purpose, which turns out to be very effective.
    Here are all the parts:
    - a main body (out of hex stock)
    - Two small screws, center drilled, and with a conical tip. They will act as drilling bushings to guide the drill bit.
    - A tapped transversal support, that will hold the ball post while being drilled.
    Here you can see how the ball post is hold in place inside the fixture.
    The two screws will guide the drill bit. One is center drilled at 2mm, and the other at 1.5 mm, so the same fixture can be used for the two different sizes required, you just have to revert it upside down.
    Everything assembled, ready for drilling.
    one drop of oil
    And here we go
    What we obtain :
    Perfectly true :
    I can show here an example of what the finished key looks like (on my last instrument) :
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 18 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (Jan 18, 2023), bgerens (May 5, 2018), DIYer (May 5, 2018), emu roo (Dec 30, 2025), Home-PC (Dec 10, 2020), JoeH (Dec 27, 2018), Jon (May 5, 2018), Miloslav (Dec 26, 2018), mklotz (Dec 27, 2018), NortonDommi (May 7, 2018), phred (Jan 18, 2023), PJs (May 7, 2018), richardcrane (May 5, 2018), rossbotics (May 5, 2018), Seedtick (May 6, 2018), Sleykin (Jan 17, 2023), that_other_guy (Jan 7, 2019), Tonyg (Dec 11, 2020)
    Thanks Christophe Mineau! We've added your Ball Post Drilling Fixture to our Luthiery category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    emu roo (Dec 30, 2025), phred (Jan 18, 2023)
    Dec 2013
    Florida
    rossbotics's Tools
    Beautiful work Christophe
    Doug
    Comments are always welcome
    Doug
  6. The Following User Says Thank You to rossbotics For This Useful Post:
    Oct 2012
    Christophe
    Beautiful work, I'd like to see a little bit more of how it is done.
    Very nice work
    Nelson
  8. The Following User Says Thank You to ncollar For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    WOW, once again Thank You,
    Ralph
  10. The Following User Says Thank You to Ralphxyz For This Useful Post:
  11. #6
    I had a somewhat similar problem. In my case, I needed to drill two orthogonal holes through 1/8" diameter brass balls used as part of miniature universals. The jig and procedure is described here...
    http://www.homemadetools.net/forum/d...-spheres-27292
    Drilling larger holes in larger spheres involves a different approach...
    http://www.homemadetools.net/forum/d...-spheres-27291
  12. The Following User Says Thank You to mklotz For This Useful Post:
  13. #7
    JoeH's Avatar
    Mar 2018
    beautiful work, Christophe.
    Download plans for luthiery tools.
  14. The Following 2 Users Say Thank You to JoeH For This Useful Post:
    Christophe Mineau (Dec 28, 2018), emu roo (Dec 30, 2025)
