Results 1 to 10 of 14
Thread: 2 piece milling vice
    Jun 2018
    Stevohdee's Tools
    hey fellow shed dwellers,
    I saw one of these online while searching for vice styles, had to have one.
    Main body: mild steel
    Jaws: 01 tool steel
    Thread: 12mm stainless bolt
    The black handle is from a gas strut. While on the pushbike ride a few years back came across a cardboard box, found 50 brand new gas struts inside so balanced precariously on one leg and riding one handed got them home, wasn't gunna leave them to get car.
    Have since used a few for handles on several pieces, the rods have a tough case hardened finish with an 8mm thread.
    cheers stevoh
  2. The Following 26 Users Say Thank You to Stevohdee For This Useful Post:
    albertq (Dec 15, 2023), almarghi (Oct 24, 2018), bigtrev8xl (Jul 8, 2018), bruce.desertrat (Jul 4, 2018), Canyonman44 (Aug 12, 2020), Eaglewood (Oct 24, 2018), emu roo (Mar 28, 2023), fergiomaria (Dec 15, 2023), freddo4 (Aug 12, 2020), high-side (Oct 25, 2018), hook86 (Oct 24, 2018), jackhoying (Oct 25, 2018), JoeH (Jul 3, 2018), Jon (Jul 2, 2018), mr mikey (Mar 28, 2023), nova_robotics (Mar 28, 2023), olderdan (Jul 4, 2018), philipUsesWood&Brass (Jul 4, 2018), Ralphxyz (Aug 13, 2023), rendoman (Jul 2, 2018), rossbotics (Jul 3, 2018), Seedtick (Jul 2, 2018), Sleykin (Jul 2, 2018), sossol (Jan 31, 2023), UncleBob (Oct 24, 2018), volodar (Oct 24, 2018)
    Supporting Member Drew1966's Avatar
    Oct 2016
    Very nice Stevohdee, thank you.
  4. The Following User Says Thank You to Drew1966 For This Useful Post:
    Stevohdee (Jul 2, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Super clean build Steveohdee, and gas cylinders are another recycle in common. I like that you can put almost any size into it and hold it well, and have often thought of this kind of vice but concerned about keeping the jaws parallel because of the slop in the T-nuts. I guess you could tram the jaws each time it's set up for the size work to hold. Do you have another way or is it even important?
    Thanks for sharing a fine build with us.
    PJ
    Mark Twain
    Jun 2018
    Stevohdee's Tools
    PJ
    Thaks pj,
    to set vice up i just square both sides with set square against mill table then tighten down, no need to tram.
    Cheers stevoh
  7. The Following 2 Users Say Thank You to Stevohdee For This Useful Post:
    hook86 (Oct 24, 2018), PJs (Jul 5, 2018)
    Oct 2012
    For some square is not good enough. I picked up one of the pieces of a two piece manufactured vise like that and was going to make the solid end of the combo. I do not see any reason that would change very much if everything is hardened.
    Very nice and clean job. I sure it will serve you well.
    Nelson
  9. The Following User Says Thank You to ncollar For This Useful Post:
    PJs (Jul 5, 2018)
  10. #6
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by ncollar View Post
    Nelson
    Thanks nelson, tramming will confirm that the ol' eyes are still working ok and you havent missed a gap between the table and workpiece. I did tram a couple of times when i first made it and found was out by a country mile once so I used a torch and magnifyer, yep, I'm getting old. So your right, tramming should be done regardless if you wanna make sure
    Cheers stevoh
  11. The Following User Says Thank You to Stevohdee For This Useful Post:
    PJs (Jul 5, 2018)
  12. #7
    JoeH's Avatar
    Mar 2018
    Thank you for posting this. I had been thinking of building something similar but had not worked out a good way to capture the drive screw. Very cool.
  13. #8
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by JoeH View Post
    Thanks joe, glad it helped
    Cheers stevoh
  14. #9
    Thanks Stevohdee! We've added your Mill Vise to our Vises category,
    as well as to your builder page: Stevohdee's Homemade Tools. Your receipt:
  15. #10
    olderdan's Tools
    Nice work and very useful, I made a small version for my lathe cross slide only to find I could not use it as it locked the slide due to distortion.
    Unlike a stand alone clamp it transfers the clamp force to the bed, fine on a robust machine.
    Oh well at least the long T nuts are still to be used. Great find on the gas struts.
  16. The Following User Says Thank You to olderdan For This Useful Post:
    PJs (Jul 5, 2018)
