Hi! I am making a belt sanding machine. Use everything that he found in his garage, metal plates, aluminum scrap to be molten.
Attachment 8005
Attachment 8006
Attachment 8007
Attachment 8008
Attachment 8009
Attachment 8005
Attachment 8006
Attachment 8007
Attachment 8008
Attachment 8009
Aluminum scrap Melting, received here are blanks for rollers and pulley on the engine.
Attachment 8010
Attachment 8011
Attachment 8012
Attachment 8013
Attachment 8014
Attachment 8015
Attachment 8016
Attachment 8017
Attachment 8018
Running belt grinder after 1.27 minutes
https://www.youtube.com/watch?v=IXUK8cHn0i4
Wow, that is an impressive homemade tool build using your own aluminum castings and then machining the cast parts on your homemade lathe to make another homemade tool. Thank you for the posting and video, Paul
Thanks Vyacheslav.Nevolya! We've added your Belt Grinder to our Grinding category, as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/belt-grinder-63"><img src="http://www.homemadetools.net/uploads/142403/belt-grinder-63.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/belt-grinder-63">Belt Grinder</a> <span> by <a href="/builder/Vyacheslav.Nevolya">Vyacheslav.Nevolya</a></span> </div> <div class="tags">tags: <a href="http://www.homemadetools.net/tag/belt-grinder">belt grinder</a>, <a href="http://www.homemadetools.net/tag/motor">motor</a></div> </div> </div> </div>
Great build! Very good machining! What size belt does it take?
The minimum length of belt 800mm, maximum 1400mm. Belt myself produce, cut into strips and glue.Attachment 8357
Hi Vyacheslav.Nevolya,
Very impressive scratch build! Your Belt Grinder is the 'Tool of the Week'!
As you've already received one of our official HomemadeTools.net T-shirts, we'd be glad to award you a $25 online gift card.
Just let me have your email address via PM and we'll get things processed directly.
Congrats!
Ken
