Remove advertisements
Results 1 to 6 of 6
Thread: mini self centering vice
    Jun 2018
    Stevohdee's Tools
    hey fellow creators,
    Thought I'd share one of my favorite tools. this little baby is used often, it locks like superglue and the step in the jaws saves scrounging for
    levels, easy to square on the mill.
    overall length:97mm
    width:55mm
    height:43mm
    thread 10mm left and right of course
    base:8mm mild
    side channels:16mm mild
    jaws:1/4" O1 tool steel heat treated to 55 Rockwell
    The handle has a spring with a ball bearing inside to hold handle in upright or level position, note dimple in small part of handle.
    The base I opted to attach with screws rather than gouge out to be able to adjust the clearance.
    cheers stevoh
  2. The Following 16 Users Say Thank You to Stevohdee For This Useful Post:
    aphilipmarcou (06-20-2018), jjr2001 (06-20-2018), Jon (06-20-2018), LMMasterMariner (06-20-2018), Miloslav (10-23-2018), mwmkravchenko (10-23-2018), NortonDommi (06-20-2018), olderdan (06-30-2018), Paul Jones (06-20-2018), philipUsesWood&Brass (06-23-2018), PJs (06-21-2018), rgsparber (06-20-2018), rossbotics (07-03-2018), Saltfever (10-24-2018), Seedtick (06-21-2018), sossol (10-24-2018)
    aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    Great design there. How have you fixed the cross piece that engages with the groove in the threaded rod?
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by aphilipmarcou View Post
    Thanks for you message, the cross piece is sitting in milled channels either side just shy of the upper lip. It just slides in from bottom when base is off. Drilled hole same time as thread holes in jaw bodies so all lined up. Assembled sides, cross piece, jaw bodies & base, drilled the lot 7.5mm then removed cross piece then drilled 8.5mm for 10mm thread. Cross piece was high enough to drill complete hole then cut to accept thread from top. Hope this makes sense
    Cheers stevoh
  5. The Following 4 Users Say Thank You to Stevohdee For This Useful Post:
    aphilipmarcou (06-29-2018), Paul Jones (06-20-2018), philipUsesWood&Brass (06-23-2018), PJs (06-21-2018)
    Oct 2016
    Hei Stevoh
    I really like your vice.
    Any chance to get some more dimensions or even a plan of the "front face" ?
    Pigi
    Jun 2018
    Stevohdee's Tools
    Thanks Pigi,
    here's another pic to hopefully explain what's goin on
    jaws are 15.5mm high, body of jaws 14mm high from base,
    spring loaded handle with ball bearing
    Content Editor DIYer's Avatar
    Thanks Stevohdee! We've added your Self Centering Vise to our Vises category,
    as well as to your builder page: Stevohdee's Homemade Tools. Your receipt:
    Post your reply!
  9. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    high-side (10-24-2018), olderdan (06-30-2018)
