I am curious to know if the plans are scalable. I have a 5' x 10' CNC router table that needs around 30A of 208VAC three phase and the accompanying vacuum pump is another 10HP....
This will be a hand drawing. I have to redo it. Give me time its coming. Bean real busy latly
The short answer is 'yes' Lintelle. The pony motor doesn't care and the idler (3-phaes generator [kind of]) must be 1.33 times the total final load. The idler's associated fusing must be no more than 1.25 times the total load. The wiring must be capable of the total running under load ampere requirement. If you'll post the total HP and application 3-phase voltage (208 I guess), I'll research what you'll need but you will need to have a local, licensed electrician give my numbers his blessing.
Rotary type will work on 220 v 50 hz
FYI in 2000's they change the voltage to 240v still 50hz see http://ewh.ieee.org/r10/nsw/subpages...e-Voltages.pdf
What size are planning on building???
Dave
