Results 1 to 10 of 18
Thread: Warco Saddle Stop
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Warco Saddle Stop
    Although I'm not a big fan of lathe saddle stops I've got to the point where I thought it might be a good idea for certain repeat tasks and hence I've set out and made this for the Warco WM240B lathe.
    The result is a cast iron block that hangs over the saddle and locks with a nut. The stop itself then is a threaded bar that has a simple locking knurled wheel. All quite simple to make and more details are here: Warco Saddle Stop
  2. The Following 13 Users Say Thank You to editor@glue-it.com For This Useful Post:
    high-side (Jan 14, 2019), Home-PC (Dec 30, 2020), HUMARIA (Dec 31, 2020), Jon (Jul 23, 2018), Miloslav (Mar 21, 2019), Paul Jones (Jul 23, 2018), PJs (Jul 22, 2018), rossbotics (Jul 24, 2018), Seedtick (Jul 23, 2018), Stevohdee (Jul 27, 2018), suther51 (Jul 23, 2018), Tule (Jan 10, 2019), zarembak (Jan 9, 2019)
    Supporting Member scrdmgl's Avatar
    Oct 2013
    Toronto, Ontario, Canada
    scrdmgl's Tools
    Stop Ends
    Hi Nigel:
    Excellent design and finish of the components. I only have a suggestion for you. Any and all stops (lathe saddle, milling vise, etc.) are better provided with a round or convex contact area. The idea being that is easy for chips and any other debris, to stick to a flat surface messing up the accuracy of the location. Less so to the said end thus shaped.
    Cheers
    Jorge
    Jul 2016
    There have been several stops posted that I have taken notice of, so by chance you are the one that I will ask sense I finally have enough motivation to post a question about them. I do not believe that I have yet seen a post that clearly shows how the stop clamps to the ways of the lathe. Perhaps a picture of the clamp side will be answer enough. Does the clamp or lock nut simply register on the underside of the ways? To be honest I have not owned my lathe long enough to have thought to look at the underside of the ways to see how much of a ledge is there. My lathe is a 12x32 enco of 1990 vintage. Just getting started with it. Finding out that "good condition" can have a more varied meaning than I would have thought. Oh well live and learn. Thanks in advance.
    Eric
    Most of the stop blocks I have used or encountered clamped like I have shown in the drawing picture
    The basic block is milled to fit the way the clamp has a raised fulcrum to connect to the block held in place by a simple bolt from underneath
    Some blocks will have the thread in the clamp and the bolt passing from the top .
    the clamp will extend as far as required under the bottom of the way. usually depending on the size of the lathe it could be a little as .250" or as much as an inch or more.
    Home-PC (Mar 19, 2021), Paul Jones (Jul 23, 2018)
    Eric, good condition is a poorly over used term when someone sells a machine.
    Particularly if they are not a machinist or have not operated the machine in question. To them good condition may mean everything moves or it switches on and runs.
    Rarely if ever are any spec sheets supplied stating current tolerances, back lash, run-out etc
    I've found some machines for sale claiming to have been refurbished only to find out the seller had done the refurbishment using little more than cleaning solvents and spray paint. I have even bought some if the price was right and the paint job was good quality, Knowing that as long as there wasn't too much wrong with it I could scrape square and tighten up where needed and make a decent machine out of it
    Oct 2013
    scrdmgl's Tools
    How true it is Frank. The same word or definition, can have a different meaning for many people. That is akin as saying "an honest politician" when in fact is a contradiction in terms.
    Cheers
    George
  9. #7
    Dec 2013
    Florida
    rossbotics's Tools
    Quote Originally Posted by editor@glue-it.com View Post
    Looks great, you did a nice job of it
    Doug
    Comments are always welcome
    Doug
  10. #8
    Thanks editor@glue-it.com! We've added your Lathe Saddle Stop to our Lathe Accessories category,
    as well as to your builder page: editor@glue-it.com's Homemade Tools. Your receipt:
  11. #9
    Jul 2016
    I took the opportunity to stop by my shop while walking the dog to night. The ledge under the way on the lathe is 1/4 inch. Adequate I should think. But this brings up another question, the total depth of the ledge is actually 11/16. The difference is accounted for by the presence of a gear rack. Now I have yet to find an answer for the existence of 2 means of powering the carnage up and down the ways, lead screw and gear rack. Lead screw would be more accurate I am thinking. Could the gear rack be for broaching? Take more stress? It has much more lash than the screw. Is this some sort of chineesium lost in translation? I have down loaded the owners manual for the enco and the apparent grizzly clone but found nothing there. Any thoughts would be appreciated. Thanks
    Eric
  12. #10
    Jul 2016
    After a quick look the grizzly g4003 also has the rack. Must be some good reason for it just a newby to metal lathe work.
    Eric
