Homemade LB7 Fuel System Repair Verifying Tool
bullfrogjohnson on duramaxdiesels.com
Homemade LB7 fuel system repair verifying tool intended as a means of checking the return line system for leaks prior to engine reassembly. Consists of a Mityvac handheld vacuum/pressure gauge and tubing, the end of a surplus fuel return line, a fuel return line bolt, and a banjo washer. Tool is installed on the cylinder head's fuel return outlet to apply vacuum to the system.
URL:
FILES:
- Making flip-flops - GIF by Altair on 2024-04-26 12:56:01
- Instagram models - GIFs by InstagramBot on 2024-04-26 12:01:02
- Chamber Headspace Gage by alainbiggun on 2024-04-26 11:41:06
- Long reach floating excavator - GIF by BuffaloJohn on 2024-04-26 11:10:26
- Students cutting wood using a hacksaw - GIF by NeiljohnUK on 2024-04-26 11:03:38
- Right angle drill attachment - GIF by BuffaloJohn on 2024-04-26 10:49:59
- Mortise and tenon felling cut - GIF by Altair on 2024-04-26 10:27:01
- Pit pony lowering harness - photos by albertq on 2024-04-26 09:31:42
- Inflated animal skin floatation device - GIF by albertq on 2024-04-26 09:12:07
- Holdout houses compilation - GIF by albertq on 2024-04-26 09:02:46
DIY LB7 Fuel System Repair Verifying Tool - comment on how to build a LB7 Fuel System Repair Verifying Tool - 0 comments
Be the first to comment on this DIY LB7 Fuel System Repair Verifying Tool, or add details on how to make a LB7 Fuel System Repair Verifying Tool! Click the "add comment" button above to comment.
