Results 1 to 10 of 15
Thread: [Leather Working] Saddle stitching awl (diamond shape blade)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Here are a couple of stitching awls I have made, build from scratch, blade and handle.
    The two awls I have made are the two at the front, the one at the back is a vintage commercial one, for heavy duty leather work.
    One of the handles is made of ash, and the other from ebony.
    Here is how the blades are made, starting from a hardened concrete nail :
    First, roughing out with a high speed grinder (I frequently dip the blade in a jar of water before it looses its temper).
    I grind four faces, in a kind of sword shape.
    I made a small batch blades of different width
    Then I switch to the wet slow speed grinder, and I refine the edges. The tip is quite flat and cutting, and the body has a diamond shape, more intended to expand the hole than to cut it.
    And here is the mounted awl, in the ebony handle. The blade is carefully honed on a strop, it must cut leather like butter.
    And here is how it is used, with the stitching clamp I will show next time.
    Attached Thumbnails Attached Thumbnails [Leather Working] Saddle stitching awl (diamond shape blade)-alene_losange_0001.jpg
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 12 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (Dec 24, 2020), bruce.desertrat (Sep 11, 2018), bukwessul (Jan 2, 2019), Doug53 (Dec 23, 2020), emu roo (Jul 26, 2025), Jon (Sep 11, 2018), LMMasterMariner (Sep 11, 2018), Moby Duck (Sep 11, 2018), PJs (Sep 12, 2018), rossbotics (Sep 11, 2018), Seedtick (Sep 11, 2018), Stevohdee (Sep 11, 2018)
    Supporting Member Drew1966's Avatar
    Oct 2016
    Is that a stitching horse or pony?
  4. The Following User Says Thank You to Drew1966 For This Useful Post:
    Jun 2018
    Stevohdee's Tools
    Hey. Christophe, nice, neat job. Did you use 2 part epoxy to attach handles to blades? & how did you finish handles? Resin, wax, buffing compound?
  6. The Following 2 Users Say Thank You to Stevohdee For This Useful Post:
    Christophe Mineau (Sep 12, 2018), emu roo (Jul 26, 2025)
    Jul 2014
    France, Brittany !
    Quote Originally Posted by Drew1966 View Post
    Hi, not a pony, it's a French style clamp, will show it next
  8. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Jul 2014
    France, Brittany !
    Quote Originally Posted by Stevohdee View Post
    Hi Steve, no epoxy in this case, just a press fit, I wanted to be able to change the blade without too much difficulty, in case of breakage.
    The ash one is finished with Danih oil, and the ebony one just polished. A very quick pass to the buffing wheel with Carnauba wax for both.
    Note that the brass ferule has it's edge smoothed, in order to avoid hurting the leather.
  10. The Following User Says Thank You to Christophe Mineau For This Useful Post:
  11. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Nice work Chris
    Doug
    Comments are always welcome
    Doug
  12. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
  13. #7
    Thanks Christophe Mineau! We've added your Stitching Awls to our Leathercraft category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  14. The Following User Says Thank You to DIYer For This Useful Post:
  15. #8
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Christophe Mineau,
    Very, Very nice work on those beautiful hand tools.
    Dick
    Links to some of my plans:
  16. The Following User Says Thank You to old_toolmaker For This Useful Post:
  17. #9
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Beautiful made Stitching Awls, great pics and write up, Christophe! Thank you. Look forward to your "French Style Clamp" post.
    PJ
    Mark Twain
  18. The Following User Says Thank You to PJs For This Useful Post:
  19. #10
    Dec 2017
    Cape Coral, FL
    Christophe Mineau,
    What is that beautiful wood that was used in the dark handle? That is really set off nice with the brass ferrule!
    Dick
  20. The Following User Says Thank You to old_toolmaker For This Useful Post:
