Results 1 to 9 of 9
Thread: 1" beltsander/grinder
    Supporting Member Bellevue Woodshop's Avatar
    Mar 2018
    Norway
    Bellevue Woodshop's Tools
    1" Belt Sander/Grinder
    I built a beltsander for a 1" belt, to be able to sand very tight spots on some plywood figures I made.
    This unit turned out to be very useful.
    Video in the bottom of the post!!
    1" beltsander/grinder-uten-navn.jpg
    1" beltsander/grinder-img_1419.jpg
    All the parts are made from baltic birch plywood and a few bearings along with nuts and bolts.
    The powertrain is an old corded powerdrill.
    1" beltsander/grinder-img_1407.jpg
    1" beltsander/grinder-img_1408.jpg
    The right side of the sander contains a dust port, and is removable for belt change.
    1" beltsander/grinder-img_1415.jpg
    1" beltsander/grinder-img_1403.jpg
    A thin support platen is installed behind the lower half of the belt, and the upper part can be used for flex sanding.
    1" beltsander/grinder-img_1421.jpg
    The wheels are plywood discs turned on the lathe.
    This is the upper wheel that is used for tightening the belt, and for the tracking.
    1" beltsander/grinder-wheel.jpg
    1" beltsander/grinder-wheel2.jpg
    The left side cover, housing the powerdrill, has the power switch as well as vent holes for the heat dissipation for the motor.
    1" beltsander/grinder-img_1406.jpg
    I also made some plans/measured drawings available for the sander if you would like to build it yourself.
    1" beltsander/grinder-belt-sander.jpg
    And a couple of videos on Youtube showing assembly and showing it in action:
    Want more homemade tools inspiration? Visit my website: www.bellevuewoodshop.com
    Facebook: Bellevue Snekkeri
    Instagram:bellevuewoodshop
  2. The Following 18 Users Say Thank You to Bellevue Woodshop For This Useful Post:
    billster (Apr 9, 2018), Canobi (Apr 11, 2018), dubbby (Jun 13, 2020), emu roo (Feb 27, 2026), Glueman2 (Apr 9, 2018), HobieDave (Mar 31, 2020), Jon (Mar 29, 2018), kboy0076 (Nov 16, 2022), LMMasterMariner (Apr 3, 2018), Paul Jones (Mar 30, 2018), Philip Davies (Jul 23, 2025), PJs (Mar 29, 2018), rlm98253 (Nov 4, 2022), rossbotics (Apr 3, 2018), Seedtick (Mar 29, 2018), Tuomas (Mar 29, 2018), volodar (Aug 2, 2018), WmRMeyers (Nov 16, 2022)
    Jyväskylä Finland
    Tuomas's Tools
    Very nice build!
  4. The Following User Says Thank You to Tuomas For This Useful Post:
    Mar 2018
    Norway
    Very nice build!
    Thank you Sir.
  6. The Following User Says Thank You to Bellevue Woodshop For This Useful Post:
    Thanks Bellevue Woodshop! We've added your Belt Sander to our Sanding category,
    as well as to your builder page: Bellevue Woodshop's Homemade Tools. Your receipt:
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Bellevue Woodshop,
    This is a very unique build that most of us could attempt to make in our shops using materials at hand. I like your powertrain using an old corded powerdrill.
    Thank you for your tool inspiration and providing lots of details.
    Paul Jones
  10. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    emu roo (Feb 27, 2026), PJs (Aug 2, 2018)
  11. #6
    Mar 2018
    Norway
    Bellevue Woodshop,
    Paul Jones
    Yup it should be do-able for everybody. Main reason for building this is also that these are rarely available her in Norway, and if you get them, they are waaaay to expensive.
    Thanks for the kind feedback Paul
  12. The Following 2 Users Say Thank You to Bellevue Woodshop For This Useful Post:
    emu roo (Feb 27, 2026), Paul Jones (Mar 30, 2018)
  13. #7
    Dec 2013
    Florida
    rossbotics's Tools
    Nice build, love ingenuity
    Doug
    Comments are always welcome
    Doug
  14. The Following User Says Thank You to rossbotics For This Useful Post:
  15. #8
    Aug 2016
    wizard69's Tools
    That is one nice build! Looks like a device suitable for the show room.
    I must ask about the motor though, does it supply suitable power? The reason I ask is because the Grizzly unit I purchased is so under powered that it is basically useless even for wood working. I'm actually thinking about repowering with a larger motor or just making a new one. 1" strip sanders are incredibly useful so I need to work something out.
  16. The Following User Says Thank You to wizard69 For This Useful Post:
  17. #9
    Oct 2020
    J'ai acheté ton plan et je mis met dans pas long, reste a trouver le papier sabler de 1 pouce maintenant.
    Download plans for belt sanders and grinders.
  18. The Following User Says Thank You to kboy0076 For This Useful Post:
