Results 1 to 5 of 5
Thread: 123/2 blocks
    123/2 blocks
    123 blocks are very useful devices, both for setups and also for simplifying measurements as I showed here...
    http://www.homemadetools.net/forum/m...g-tapers-55135
    Much of what I do is on a smaller scale, though, so 123 blocks are a bit oversized many times. I decided to make a half-scale set of blocks with dimensions 1/2 - 2/2 - 3/2 or, in simpler nomenclature, 123/2 blocks.
    They're not NASA-grade precision but, even so, they've proven to be very handy indeed. I use them by themselves and also in conjunction with their full-size "parents" on those rare occasions where a larger setup is needed.
    I haven't drilled and tapped them yet. I had planned to wait until a need for holes arose and, so far, it hasn't so they remain blank.
  2. The Following 13 Users Say Thank You to mklotz For This Useful Post:
    bobs409 (Apr 26, 2018), Charron63 (Dec 11, 2017), high-side (Aug 17, 2018), Jon (Dec 6, 2017), JRock (Apr 25, 2018), kngtek (Dec 7, 2017), Miloslav (Dec 19, 2018), Paul Jones (Dec 6, 2017), philipUsesWood&Brass (Aug 16, 2018), rossbotics (Dec 7, 2017), schuylergrace (Jun 19, 2023), Seedtick (Dec 6, 2017), Toolmaker51 (Dec 6, 2017)
    Feb 2015
    Prescott, AZ
    Shelly142's Tools
    Marv,
    Great idea, especially the measurement of tapers. The simple approach is always the best.
    Shelly
    Thanks mklotz! We've added your Half Scale 123 Blocks to our Measuring and Marking category,
    Mar 2018
    Thanks Marve; I have been machining for a long time, and have never seen this process explained so simply. This shows that you are never to old to learn!!!
  6. The Following User Says Thank You to user name blacksmith For This Useful Post:
    Paul Jones (May 12, 2018)
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang: I find the 123 blocks that you can screw together and form angle plates, etc, the most useful.
    123/2 blocks-123-blocks.jpg 123/2 blocks-block-set.jpg
    ARC Euro Trade had some 1-2-4 cm blocks for metric folks and also 2-4-8 blocks. Handy for smaller work.
    Carl.
