Results 1 to 10 of 18
Thread: 24" X 1" Belt Grinder
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Made small 24" x 1" belt grinder for my little workshop.
    As my workshop is only 3 x 2 meters (6 square meters) and already have lathe, milling/drilling machine, 2 benches, etc inside, there is no much room left for big machines. Actually I don't need 72" x 2" belt grinder at all. This small one is all I need.
    Materials used:
    mild steel, 304 and 316 st. steel, 6061 aluminum, angle grinder.
    Unfortunately cordless grinder died. The only 2 good things about this cordless grinder were: 1. cordless, which is good as you don't need extension cables when moving it out of workshop and 2. several speeds for various materials and various grits belts. All the rest wasn't so good. No enough power for this task to start with, spindle lock button, etc... Lidl brand Parkside came with 3 years warranty, so I returned it to them.
    Either drive wheel or tracking wheel must be crowned (barrel shaped), not the contact wheels. As drive wheel is perfectly fabricated and well balanced, I crowned tracking wheel. This is the blue one, which I ordered from aliexpress. They call it chain roller tensioner. I bought 3 of them as they were very cheap and I was too lazy to make them.
    Later I just replaced them with ball bearings (62200 - 2RS1, 10 x 30 x 14 mm)
    3 drawings attached and the rest can be seen in the video clip.
    Cheers
    LMMasterMariner
Name:	PRINT BS 02.jpg
ID:	39693   Click image for larger version.
Name:	PRINT BS 03.jpg
ID:	39694   Click image for larger version.
Name:	PRINT BS 04.jpg
    Last edited by LMMasterMariner; May 30, 2021 at 02:51 PM. Reason: new not distorted video with proper title posted
  2. The Following 10 Users Say Thank You to LMMasterMariner For This Useful Post:
    DIYer (May 31, 2021), DIYSwede (May 30, 2021), emu roo (Jul 20, 2024), Home-PC (Jun 7, 2021), johncg (Jun 5, 2021), Jon (May 30, 2021), NortonDommi (Jun 19, 2021), old_toolmaker (Jun 3, 2021), RetiredFAE (May 31, 2021), Tonyg (Jun 1, 2021)
