Results 1 to 10 of 11
Thread: 3-1/4 inch dividing head
    Mar 2018
    New England, USA
    threesixesinarow's Tools
    This dividing head replaces a more delicate one I made from Unimat parts. It combines features from Hardinge and Cincinnati dividing heads but is simpler and a lot smaller.
    Like those, it indexes indirectly, in this case with a 40:1 ratio, or directly by disengaging the worm, and it tilts from about -5° to 90°. It has a brake to lock the spindle, and works with a small adjustable tailstock.
    It’s not universal - the hub for dividing plates is stationary. I mostly just use combinations of change gears to make divisions, though, and figured it will be easier to add stepper motor control than to make tiny parts for a differential feature I might never use.
    It’s about 3 x 3 x 3”. The spindle nose is threaded M22-1.5, with a 16° included taper for ER-16 collets, and has a 3/8” bore. The spindle is prehardened medium carbon steel, and the bearings, worm gear and brake sleeve are bronze; the body from cast iron bar stock, and most of the base is made from a piece of heavy angle iron.
ID:	29761 Click image for larger version.
ID:	29764 Click image for larger version.
    Turning the hubs between centers, and cutting a timing belt pulley to convert it to stepper drive
ID:	29763 Click image for larger version.
ID:	29766 Click image for larger version.
    Cincinnati, and Hardinge
  2. The Following 15 Users Say Thank You to threesixesinarow For This Useful Post:
    12L14 (Jul 31, 2019), DIYer (May 21, 2019), DIYSwede (May 26, 2019), emu roo (Jun 21, 2025), Jon (May 21, 2019), mikeee (Nov 8, 2023), mwmkravchenko (Oct 30, 2019), olderdan (May 27, 2019), old_toolmaker (Jul 21, 2021), rossbotics (Jun 3, 2019), Saltfever (May 22, 2019), Scotsman Hosie (May 21, 2019), Seedtick (May 21, 2019), tonyfoale (May 25, 2019), Toolmaker51 (May 21, 2019)
