Results 1 to 8 of 8
Thread: 3-in-1 DIY Knife Sharpening System Jig
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    Thumbs up 3-in-1 DIY Knife Sharpening System Jig
    I made an universal jig for sharpening:
    - knives;
    - scissors;
    - chisels.
  2. The Following 11 Users Say Thank You to Mazay For This Useful Post:
    Altair (Aug 22, 2020), Andyt (May 19, 2020), baja (May 19, 2020), biggist (Oct 18, 2024), Crusty (May 17, 2020), dubbby (May 25, 2020), emu roo (Dec 2, 2025), Jon (May 19, 2020), Quinton 357 (May 18, 2020), Sleykin (May 23, 2020), Wildwilly (Sep 16, 2023)
    Dry Gulch, Tx
    Crusty's Tools
    That's much better than the Apex clones made from recycled plastic trash. I enjoyed seeing you use all the homemade tools to produce this sharpener as much as the project itself, and you get extra kudos for not putting on a space suit just to rub some linseed oil on the finished parts.
  4. The Following 3 Users Say Thank You to Crusty For This Useful Post:
    emu roo (Dec 2, 2025), Mazay (May 18, 2020), Sleykin (May 23, 2020)
    Thanks Mazay! We've added your Sharpening Jig to our Sharpening category,
    as well as to your builder page: Mazay's Homemade Tools. Your receipt:
    Sep 2013
    Karl_H's Tools
    I enjoyed seeing you use all the homemade tools to produce this sharpener as much as the project itself.
    I agree.
    Are you calculating/measuring angles for your edge, or just getting close enough to the existing angle?
    I am sure that tomato can't tell an 8 degree angle from a 9 degree angle.
    Thanks for sharing!
    Karl
  8. The Following 2 Users Say Thank You to Karl_H For This Useful Post:
    emu roo (Dec 2, 2025), Mazay (May 19, 2020)
    Dry Gulch, Tx
    Crusty's Tools
    If you're not reprofiling an edge, the best way to set the angle is to draw on the bevel with a sharpie, then find the correct angle using light test strokes that grind fully across the edge bevel by observing the ink taken off.
  10. The Following 6 Users Say Thank You to Crusty For This Useful Post:
    baja (May 19, 2020), emu roo (Dec 2, 2025), Jon (May 19, 2020), Karl_H (May 18, 2020), Mazay (May 19, 2020), SASocal (May 26, 2020)
  11. #6
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    Quote Originally Posted by Karl_H View Post
    That's a great tomato joke. You made me laugh.
    I am using protractor application on a smartphone. It turns out a very accurate measurement.
    At first, I planned to calculate the angle according to the size of the device, this would give an accuracy of about + - 1 degree, taking into account the different projections of the knife tip. Based on the calculations, just make a set of sticks that would allow you to quickly measure the distance from the base to the bottom of the hinge. But using the application turned out to be easier, with higher measurement accuracy.
  12. The Following 2 Users Say Thank You to Mazay For This Useful Post:
    emu roo (Dec 2, 2025), Karl_H (May 19, 2020)
  13. #7
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    This is a good tip - I use a felt-tip pen when sharpening a chisel and a scissor (I prefer to sharpen knives on the protractor)
  14. The Following User Says Thank You to Mazay For This Useful Post:
  15. #8
  16. The Following 4 Users Say Thank You to Mazay For This Useful Post:
    emu roo (Dec 2, 2025), Jon (May 22, 2020), Karl_H (May 22, 2020), Sleykin (May 23, 2020)
