Results 1 to 7 of 7
Thread: 3 angle bevel attach for Victor 1350 torch
    Supporting Member oldtimer's Avatar
    Jan 2016
    oldtimer's Tools
    If you use a Victor 1350 torch, this may interest you. When cutting bevel cuts like 30-45-60 degrees, clamp it on the torch and use a length of angle iron as a straight edge. Works great3 angle bevel attach for Victor 1350 torch-100_2027.jpg3 angle bevel attach for Victor 1350 torch-100_2026.jpg3 angle bevel attach for Victor 1350 torch-100_2028.jpg
  2. The Following 15 Users Say Thank You to oldtimer For This Useful Post:
    Andyt (Mar 16, 2018), clydeman (May 26, 2020), high-side (May 27, 2020), HobieDave (Apr 5, 2020), jackhoying (Mar 15, 2018), Jon (Mar 15, 2018), mr mikey (Jan 26, 2023), mudnducs (Mar 19, 2018), mwmkravchenko (Feb 6, 2024), NortonDommi (Jul 12, 2018), oldcaptainrusty (Mar 15, 2018), piro222 (Mar 16, 2018), Seedtick (Mar 15, 2018), Tuomas (Mar 16, 2018), WinDancerKnives (Mar 15, 2018)
    Thanks oldtimer! We've added your Cutting Torch Bevel Mount to our Cutting Torches category,
    as well as to your builder page: oldtimer's Homemade Tools. Your receipt:
    rlm98253 (Mar 15, 2018)
    Dec 2016
    Ralphxyz's Tools
    Now that is the nicest angle attachment I have seen. Thanks for posting.
    I'd like to see the angle iron straight edge.
    Ralph
    WinDancerKnives's Avatar
    Jul 2016
    Consider this great idea stolen, OldTimer
    Thanks for posting,
    Dave
    Jyväskylä Finland
    Tuomas's Tools
    That's a good design. We have those ones with the sliding adjustments at work. Those allways get loose in use and angle changes, then you tighten the screw ( when its hot ) and next time you use it, its difficult to get that screw opened. This one seems much better.
    Tuomas; I was thinking the same thing I used to have one of those Curv-o-mark guides as well I found them to be fiddly at best The best thing that ever happened for me was when someone borrowed it and never returned it
  9. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    mr mikey (Jan 26, 2023), Tuomas (Mar 16, 2018)
  10. #7
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    Borrowing tools. If someone asked and I had two I would lend the worn out one knowing it's not coming back.
