3 simple way to make Water Pump at home
https://youtu.be/8L2RFpjkurs Hello friends, today I want to show you 3 simple ways to make Water Pump at home.
The first is with the help of a drill. I will make the construction Powerful Water Pump , This is a really useful project, can be easily made at home, With drill and PVC pipe. This little pump suck 10 liter water for 4 seconds and would be great for backyard water tanks from captured rain house gutters. or watering your garden from a solar charged battery!
The second has a DC 775 engine.
In this video, I am using a 775 motor, and i will the construction Powerful Water Pump 12volt, This is a really useful project, can be easily made at home, With 775 motor. This little pump would be great for backyard water tanks from captured rain house gutters. or watering your garden from a solar charged battery!
The third is a hand pump.In this project you'll learn how to make a customizable PVC hand pump that will create vacuum suction, pump water, or compress air.
A pre-requisite to making the pump will be 2 homemade check valves. You can learn from where you can get a valve in the video.
I hope you like the video compilation.
Original videos Link:
1. https://youtu.be/7YXnm_-V7SI
2. https://youtu.be/W3Api0gmiHs
3. https://youtu.be/diky7yoHQr4
