Results 1 to 8 of 8
Thread: 3D-Printed MT-3 (Morse Taper) Shelf Inserts
    Supporting Member MetalDesigner's Avatar
    Sep 2013
    Las Vegas ~ @MetalDesigner Twitter
    MetalDesigner's Tools
    Built some new metal shelves for the Lathe area and needed a way to hold the new Lathe’s (Morse Taper) MT-3 tooling secure.
    3D-printed ABS plastic inserts seemed like a solution …
    I could have used rubber Grommets ... but where is the fun in that?
    3D-Printed MT-3 (Morse Taper) Shelf Inserts-mt-3-tooling-3dprinted-inserts-1.jpg
    Designed the ABS plastic inserts using SolidWorks CAD Software ~ The inner hole has the same 1.4377 degree taper from center line as the MT-3 Tooling.
    Converted the SolidWorks CAD file into a 3D-Printing STL file and started the 3D-Printer ...
    3D-Printed MT-3 (Morse Taper) Shelf Inserts-3d-printing-mt-3-abs-inserts.jpg
    The finished 3D-Printed ABS plastic inserts pressed into the 1.5″ diameter holes I cut in the sheet metal shelf using a hole-saw on the drill press.
    Once the MT-3 Tooling was secure in the 3D-Printed inserts … Decided to make a ‘quick access’ 3D-Printed ‘Cup Holder’ for the drill chuck key.
    3D-Printed MT-3 (Morse Taper) Shelf Inserts-close-up-view-3d-printed-cup.jpg
    Found some scrap 5/8″ round-stock steel and used the lathe to bore a hole in it the same size as the chuck key handle diameter … Then pressed the chuck key into the round stock creating a comfortable handle chuck key unit.
    Wanted it easy to use the Chuck Key so designed the 3D-Printed ‘Cup Holder’ type design about 1.875″ deep with a loose fitting diameter of 0.700″.
    The best part is while I kept working in the Workshop, the 3D-Printer was making the ABS plastic inserts in the house … Felt like getting twice the work done!!
    Sometimes the simplest of items can be very helpful.
    https://ctmprojectsblog.wordpress.com/about/
    ... CHEERS!! @MetalDesigner on Twitter
  2. The Following 2 Users Say Thank You to MetalDesigner For This Useful Post:
    kbalch (Dec 12, 2014), Paul Jones (Dec 16, 2014)
    Very nicely done! Those inserts definitely add a custom touch.
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Show ...
    Sorry my mistakes in english.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks MetalDesigner! I've added your 3D-Printed Shelf Inserts to our Miscellaneous and Storage and Organization categories, as well as to your builder page: MetalDesigner's Homemade Tools. Your receipt:
    Supporting Member jackhoying's Avatar
    Apr 2014
    Fort Loramie, Ohio
    jackhoying's Tools
    This is a great idea. Now I have to get my son-in-law to print some of these for me.
    Dec 2014
    These look great. Terrific idea
    Barry
  8. #7
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Great idea and design. The 3D printing application makes all the better. Thank you for showing us the concept in SolidWorks!
  9. #8
    Sep 2013
    Let me know when you have some sizes Jack and I will draw them up and either I or Keith can print you some :-)
