Results 1 to 10 of 12
Thread: 4x6 Horizontal Bandsaw mods
    jdurand's Tools
    I did these mods some time ago but just realized I should share them here. The saw is a Harbor Freight "4x6" bandsaw.
    One of the first things was new wheels to make it more stable. The bushings are made on a lathe.
    The next was to move the outer guide bearings up a bit to reduce jamming from swarf and to help make the blade vertical. I get REALLY nice cuts out of this saw. I simply chucked the guides in the lathe and made the hex part thinner.
    Then I got what was to be the first of a number of orders for custom lighting dimmers for a circus group in Canada. One part of the design needed sections of 3 inch x 6 inch aluminum tube (used to make hanging brackets). Well, I have a 4x6 saw, what could go wrong?
    Some settling must have occurred during shipping a the guide bearings hit the tube. Insert bad words here.
    The bearing guide was all the way back and the tube was all the way against the right hand stop.
    So, grab some scrap... err ... not currently used steel angle with a nice rust... err ... aged finish and make a new right hand stop. While at it, bring it right up to the blade for cutting smaller items.
    Presto, I can now cut things larger than 6 inches!
    Here's the lighting dimmer with those aluminum bits on, they hang under the seating on the X supports (like scaffolding). The dimmer provides 40 Amps @ 24VDC for LED lighting.
  2. The Following 3 Users Say Thank You to jdurand For This Useful Post:
    57_210 (Sep 19, 2022), Jon (Oct 24, 2019), Midwestern640 (Oct 21, 2019)
    Thanks jdurand! We've added your Horizontal Bandsaw Bearing Modification to our Bandsaws category,
    as well as to your builder page: jdurand's Homemade Tools. Your receipt:
    jonlegrand1's Avatar
    Oct 2019
    Houston, Texas
    jonlegrand1's Tools
    Hi, new to this forum.
    I bought one of those used last year and welded my own base for it. OK, how do you keep the blade cutting straight? I tried a few adjustments but nothing seemed to help. Tried tightening it all the way like some guys on YT suggest, still it drifts to the right using it horizontal or upright. Thanks.
    https://madebyjonlegrand.wordpress.com
  5. The Following 4 Users Say Thank You to jonlegrand1 For This Useful Post:
    Jon (Oct 19, 2019), Midwestern640 (Oct 21, 2019), skupstas (Oct 19, 2019), thehomeengineer (Oct 21, 2019)
    jdurand's Tools
    Quote Originally Posted by jonlegrand1 View Post
    There's several things that can keep it from cutting straight. Clamp a large machinists square in the vise making sure it's flat on the bed and just barely touching the blade. Raise and lower the blade and see if it tracks along the square. If not, use your favorite swear words and check the pivot for the cutting head. Usually there's no adjustment, which means you either have to make an off-center bushing or easier, put a wedge under the work to make it cut straight.
    Assuming it tracks ok, then check the blade for tilt, you may have to tweak the guide bearings a little or a lot. See my bearing mod that might help.
    Make sure your tension is good, you should get a nice boing sound from plucking the blade.
  7. The Following User Says Thank You to jdurand For This Useful Post:
    Jon (Oct 21, 2019)
    Berkshire UK
    thehomeengineer's Tools
    Not sure if This helps see link below:
    Saw not cutting stright
    The Home Engineer
  9. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Oct 22, 2019), Jon (Oct 21, 2019)
  10. #6
    Berkshire UK
    Hi
    Already thinking about doing the same as you. I have had my little saw for 30 years and it does have sentimental value as my late Mother bought it for me. But the thin base unfortunately lets it down. So after seeing your post I feel after all this time the saw could do with the base upgrade. Thank you for posting I will let you know how I get on making it.
    The Home Engineer
  11. #7
    jdurand's Tools
    Quote Originally Posted by thehomeengineer View Post
    Hi
    The Home Engineer
    Anyone making a base, the wheels should be out far enough so when you raise the arm into vertical position the center of gravity is still well inside the wheelbase. Really easy to tip one over otherwise.
  12. The Following User Says Thank You to jdurand For This Useful Post:
    thehomeengineer (Oct 22, 2019)
  13. #8
    Oct 2019
    Houston, Texas
    jonlegrand1's Tools
    Thanks, I'll try that adjustment. I played with it a few times, tightened it all the way, adjusted the blade square, and it still drifted to the right. The Harbor Junk manual that came with it is about as clear as mud on adjustments.
    I worked at a place where we had a real h-saw (an expensive Jet unit). I must have changed that blade once a month and never, ever did an adjustment on it. We did thousands of cuts and they were always as straight as can be. Sigh.
    My base upright, it's very solid:
    https://madebyjonlegrand.wordpress.c...p-carousel-140
  14. #9
    Thanks jonlegrand1! We've added your Horizontal Bandsaw Stand to our Dollies and Stands category,
    as well as to your builder page: jonlegrand1's Homemade Tools. Your receipt:
  15. #10
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    The best tip to keep the cuts straight is to get a name brand, bi-metal blade. The teeth on a cheap blade can wear more on the side that contacts the wheels and that, uneven wear will cause the saw to cut crooked. I have the same bi-metal blade on mine (a Grizzly) for the past 10 years and it is still going just fine.
    You pay about two or three times the cost of a cheap, import blade, but they last between five to twenty times longer so you spend less in the long run. I found that not only did the cheap blades not cut straight, but they also tended to break from fatigue after some months of use. That's months, not years!
    Paul A.
