The bearing came today, not with out some stress. First thing I noticed was a hairline crack in the outer race!!!!!! But after some research it is part of the manufacturing process. (Spherical bearings are new to me) The next thing that I noticed was that the angulation was listed wrong, 9 degrees not 14, this bearing is a sealed one with the same pn as one with out a seal. At 9 deg the blade will come almost 12 inches off the ground corner to corner or out of parallel with the tracks. At 14 deg just over 18 inches, more like what I envisioned. I suppose that I can run it at 14 deg and just not have a total seal at max angle. Maybe some cobbled up boot to help keep grit out. Any guidance would be much appreciated. Thanks
Eric
