Results 1 to 10 of 20
Thread: 90 degree tube notching method without a drill press.
    Jyväskylä Finland
    Tuomas's Tools
    Hi
    im not sure is this a "tool".
    But this way i notch tubes.
  2. The Following 37 Users Say Thank You to Tuomas For This Useful Post:
    baja (May 22, 2021), bruce.desertrat (Feb 13, 2018), BuffaloJohn (Jul 26, 2021), carloski (May 22, 2021), cmarlow (Jan 17, 2019), DIYer (May 8, 2017), Duke_of_URL (Jan 18, 2019), Eaglewood (Jan 17, 2019), emu roo (Jul 18, 2025), EnginePaul (Jun 17, 2018), Glebson (May 9, 2017), glenntref (Feb 14, 2018), high-side (Jan 20, 2019), JD62 (May 8, 2017), Ken Koch (Mar 30, 2019), LaVern (May 8, 2017), Moby Duck (Jun 19, 2018), nickyd (May 12, 2017), oldcaptainrusty (Feb 14, 2018), oldpastit (Jan 18, 2019), Ralphxyz (Dec 22, 2023), rebuilder1954 (Jul 1, 2024), Resident114 (Dec 21, 2023), rlm98253 (Feb 13, 2018), Ron725 (May 9, 2017), SA MAKER (May 9, 2019), Scotsman Hosie (Feb 22, 2018), Seedtick (May 9, 2017), Sprig1 (Mar 25, 2019), terence b (Jul 18, 2025), that_other_guy (Mar 25, 2019), toma (Feb 14, 2018), Tonyg (Oct 17, 2018), Toolmaker51 (Jun 17, 2018), wesser1 (Dec 21, 2023), will52100 (Jun 17, 2018), william73 (Jul 18, 2018)
    Thanks Tuomas! We've added your Tube Notching Method to our Tube Notchers category,
    Dec 2016
    Ralphxyz's Tools
    Great, never have seen it detailed before, either that was some thin tubing or they had very aggressive abrasive wheels.
    Thanks for posting,
    Ralph
  6. The Following 2 Users Say Thank You to Ralphxyz For This Useful Post:
    emu roo (Jul 18, 2025), Tuomas (May 12, 2017)
    Jyväskylä Finland
    Tuomas's Tools
    Thanks Ralph.
    Tube was with 1.6mm wall. But also those 1mm thick discs cut very fast, i like those are more accurate too than 2.4mm discs.
  8. The Following 3 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Jul 18, 2025), Paul Jones (Feb 22, 2018), sniffipn (May 22, 2021)
    Jan 2017
    Thanks Tuomas!
  10. The Following User Says Thank You to Glebson For This Useful Post:
    Tuomas (May 11, 2017)
  11. #6
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    Knock out by the precision, Tuomas. From the math, to the layout, to template, to the execution of the notches. A true craftsman.
  12. The Following 3 Users Say Thank You to Scotsman Hosie For This Useful Post:
    emu roo (Jul 18, 2025), sniffipn (May 22, 2021), Tuomas (Feb 25, 2018)
  13. #7
    There's a product here. Design templates for standard and common tube sizes and a variety of angles of intersection, 90deg. 75, 60, 45, 30 and maybe in between. Print the templates at home on heavy paper stock and ship them by 1st class mail or via internet. Or laser cut more durable templates from a thicker flexible material, incorporate a connector of some sort. The material could be strong so not to stretch or stretchy thick rubber/elastomer with ends laser cut to form a male/female joint that you glue together with ACC. This later type could be designed to fit a small range of OD's for example: 1.75, 1.88, 1.9(schedule 40 pipe) and 2". I'm thinking this particular example in a quality silicone rubber could easily sell for $4.95 plus shipping, which if it would stand being pressed flat for shipping between two sheets of cardboard, could go first class perhaps as many as a set of 6 sizes in a first class envelope. Ed Weldon (to old to start a new business)
  14. The Following 2 Users Say Thank You to Ed Weldon For This Useful Post:
    emu roo (Jul 18, 2025), Toolmaker51 (Oct 19, 2018)
  15. #8
    I forgot to mention in the product idea. I may have also produced a "poor man's patent" here by making a public disclosure in this forum of what otherwise might be a patentable idea, laser cut form and connectors that stretches to fit a variety of sizes. It could also be die cut. Careful selection or fabrication of the right material and thicknesses could accomodate the tendency for narrower widths of the template to stretch unequally. Ed W
  16. #9
    Another thought. This form could be cut with a steel rule die, a method commonly used for cutting flat gaskets. Dies are made from special thin steel strip with a sharp cutting edge embeded in thick baltic birch plywood. Check out this process. Cheaper than buying a laser. And faster production rates.
  17. The Following User Says Thank You to Ed Weldon For This Useful Post:
  18. #10
    Apr 2012
    NorCal
    Saltfever's Tools
    I remember seeing, years ago, free software that creates a template you print and then wrap around the tube to cut the profile. Joining different tube diameters at different angles can be accommodated. Here is just one example . . . there are many more.
  19. The Following 6 Users Say Thank You to Saltfever For This Useful Post:
    emu roo (Jul 18, 2025), PJs (Jun 21, 2018), Scotsman Hosie (Mar 25, 2019), sniffipn (May 22, 2021), thevillageinn (Jun 21, 2018), Toolmaker51 (Oct 19, 2018)
