Results 1 to 7 of 7
Thread: ...after a long time, I've made a grinding rig but something went wrong
  1. #5
    olderdan's Tools
    Hi Claudio
    You my get there if you provide a depth of cut adjustment for .1 mm passes, this type of grinding needs rapid passes with small cuts, very time consuming but I dont think that will bother you too much. Dry grinding generates a lot of heat very quickly and the wheel will expand as well as the metal. Angle grinding wheels are too hard for this kind of work. Maybe a belt grinding set up would work but still needing some fine adjustment. Good luck with it and thanks for the enjoyable video top marks for enthusiasm.
  2. The Following User Says Thank You to olderdan For This Useful Post:
    Claudio HG (Jun 26, 2020)
