Results 1 to 9 of 9
Thread: Air carbine muzzle brake
  1. #4
    Sig. Rendoman;
    The news media would have the world think as Americans, we can acquire any sort of firearm. Legitimate & private full-auto's are owned by those who are investigated and hold the specific federal permit. Only a couple states do not further restrict the same ownership. Arizona is one of them. The unfortunate incidents are committed with semi-auto's. The media portrays 'auto-loading' equal to 'auto-firing'; either from ignorance or intentionally. Many gun owners know the difference, there are millions of us, but can't educate the public en-mass at the media's rate of saturation. I'd like to know more about Italian firearm ownership too.
    I'm working on a sketch for you to illustrate my brake ideas. That I'll PM, maybe we can develop something; sell the plans and description?
    So, on to your project. This page Muzzle Brakes: Recoil Results for 308 & 300 Magnum - PrecisionRifleBlog.com [not a site I participate in] has a comparison of screw-on brakes, tested on .308 Win you know as 7.62×51 NATO. No firearm brakes are retained by what you call grains. 3 reasons - insecure means of locking - certainly will not install concentric to the bore - inability to insure muzzle crown 90 degrees to the bore. Depending on barrel profile, a lathe turned threaded portion about .5 to .6 long, with fine threads, a relief, and a shoulder to seat the brake against. Hole patterns distributed over the length are rotated so adjacent rows have a solid portion between. The holes usually radiate square from the bore, or at a shallow angle back. Can't find anything about surface area to bore/ cartridge capacity. There seem to be inside diameters barely larger than groove diameter, and others with a larger percentage. I know that either must be axially & radially concentric, square to bore. Some chamfered like a typical barrel, seen a few aren't. A front sight band will be an issue, although it could be fit to the brake itself with some alignment 'insurance'.
  2. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Jul 12, 2016)
