Results 1 to 10 of 13
Thread: Angle grinder holder to my miter saw stand.
    Jyväskylä Finland
    Tuomas's Tools
    Last days, i have used miter saw quite a lot for cutting metals.
    Tought that it would be usefull if grinder comes with it, then i can wipe out coarse right after cutting.
    Made this simple holder for my grinder.
    Material is 45mm pipe and 5mm steel plate. M8 screw and some rubber plugs that i have hoarded somewhere.
    Angle grinder rests between rubber plug thingys, and disc guard leans to the locking button of the stands feet.
    Grinder stays nicely on its place, even when shaking the stand. Very simple solution.
  2. The Following 12 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Mar 12, 2025), Frank S (Jan 22, 2018), Jon (Jan 22, 2018), NortonDommi (Jan 23, 2018), Paul Jones (Jan 23, 2018), philipUsesWood&Brass (May 31, 2018), PJs (Jan 23, 2018), Priemsy (Jan 23, 2018), rossbotics (Jan 23, 2018), Seedtick (Jan 22, 2018), Toolmaker51 (Jan 22, 2018), verticalmurph (Mar 13, 2020)
    Oct 2017
    say what ??? clear as mud! will need more pics and maybe a vid to understand this mod.
    Quote Originally Posted by madokie View Post
    What Tuomas has done is to make a holder which attaches to the leg of his table saw stand to hang his rt angle grinder on. This way it will be right at hand to de burr or clean up the cuts he is making without having to look for his grinder all the time. Actually a great idea as it not only saves him time it safely stores his grinder.
  5. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    philipUsesWood&Brass (May 31, 2018), PJs (Jan 23, 2018), Tuomas (Jan 22, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Hi Tuomas
    That attachment will save you some time fumbling around wondering where in the heck did I put my grinder ? that holder will come in handy in your line of work
    Comments are always welcome
    Doug
  7. The Following User Says Thank You to rossbotics For This Useful Post:
    Tuomas (Jan 23, 2018)
    Jyväskylä Finland
    Tuomas's Tools
    Thank you Frank. You explained it well.
  9. The Following User Says Thank You to Tuomas For This Useful Post:
  10. #6
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by rossbotics View Post
    Hi Tuomas
    Thanks mate!
    Yep. And because i make cuts mostly outside, its more important.
    There's quite a lot snow at the moment, now i don't need separate table for holding electric tools.
  11. #7
    Supporting Member Priemsy's Avatar
    Great idea! I'd probably make grinder the holder differently though.
  12. #8
    Sorry I said table saw what I meant was miter saw table leg.
    A holder like this would have to be made to the individual's needs.no 2 guys are likely to have the same identical saws or for that matter if they did they would have their own ideas of how to construct the holder. Tuomas has planted the seed idea of how to have your grinder atr hand. Hopefully this might be a seed of inspiration for another to design his own. I only cut wood on my 12" miter saw and rarely ever use it so no need for a grinder holder at this time.
  13. The Following User Says Thank You to Frank S For This Useful Post:
    Tuomas (Jan 24, 2018)
  14. #9
    Jyväskylä Finland
    Tuomas's Tools
    My original idea was to weld hooks for the plate, and place grinder between it. Then i noticed that hooks, ain't necessary. That's why it has two holes, but only one in use.
  15. #10
    Dec 2017
    Well thought out. Thanks
  16. The Following User Says Thank You to TLee For This Useful Post:
