Hello,Today my new DIy video Smart Idea !
Another Smart DIY IDEA || How to clean a Magnet Arrow Welding Holder from metal shavings???
https://www.youtube.com/watch?v=WiDQ3STUKqc
Me thinks if he can that much crud from the floor onto the magnet just by dropping it, ------------- maybe he better sweep the bluddy floor, eh. ;-)
Thanks Mr.DK DIY! We've added your Welding Magnet Cleaner to our Cleaning category,
as well as to your builder page: Mr.DK DIY's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-welding-magnet-cleaner"> <img src="/uploads/233603/homemade-welding-magnet-cleaner.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-welding-magnet-cleaner">Welding Magnet Cleaner</a> <span> by <a href="https://www.homemadetools.net/builder/Mr.DK+DIY">Mr.DK DIY</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/magnet'>magnet</a>, <a href='https://www.homemadetools.net/tag/cleaner'>cleaner</a> </div> </div> </div> </div>
I've always just used a blast of compressed air, effective but not necessarily the safest or cleanest way of doing things.
Compressed air, outside, pointed down, glasses on!
I get a kick out of "Thumbs Up" videos. lol
Keep it simple.Pull an old sock over your magnet .When you are done,,pull the sock off the magnet,,filings get dropped in a receptacle of your choice. Easy peasey :)
I keep my magnet in a plastic bag. Take the bag off, sweep the area, and and all the swarf falls into the bin.
Mike
Edit: Sorry, Sweep the area, take the bag off, and all the swarf falls into the bin.
Mike
Справедливое замечание Филип Дэвис. Так же много мелкой стружки и от абразивных кругов, которые налипают на магнитные угольники.
I just use my thumb and fore finger to push the crud to one corner then pinch it away from the magnet. Anything missed can be easily removed with my torch, by setting the flame to zero feather hold it near the edge of the magnet and give it a blast of the cutting oxygen. the crud will lose its attraction to a magnet at red and disintegrates as it is blown away the magnet is not hurt since the flame is always being moved in the direction, I am blowing the crud off.
But heck there have been times I probably had nearly that much metal crud in the skin of my hands and arms or under my fingernails
A wire brush works pretty well too.
I use a similar method for collecting metal on my Wen wet wheel grinder. Put the magnet in a baggie and drop it into the water trough the wheel is in. Easy to remove metal from the tank.
:beer:
Yep
Then reach into the baggie. Grab the magnet, pull the magnet out as you turn the baggie inside out over the magnet!
ALSO, I need to add, the video could have been compressed down to 10-15 seconds. We would know just as much as we do after almost 5 minutes minutes. ( only got to about 1 min) Actually we would know more, because we could have used those wasted 4 1/2 minutes to learn something else!!! :smash:
