I've had this old coffee grinder gathering dust for years. I dug it out the other day thinking I could do some repurposing. After I got it cleaned up I took some pics.
I will degrease this, as is, and spray it with clear satin to seal it up and hopefully preserve the patina.
I just hit this with a brass wire brush to clean it up. A little Tuff Stuff spray cleaner got all of the dust and brushing residue off. I took it all apart and removed the "grinding guts". These were pretty nasty...
The plan is to make a plate that will screw into the top and run the cord up thru the middle of the grinder.
Continued in next post.
Setting the plate up in the mill for some embellishment. That is a grinding stone for a Dremel tool chucked into the mill....
