Thread: Automatic infinitely adjustable milling machine quill handle.
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    Using a one way clutch, this quill handle modification allows one hand easy setting of the handle position without set increments.
  2. The Following User Says Thank You to Mook For This Useful Post:
    Jon (Feb 17, 2024)
    Thanks Mook! We've added your Milling Machine Handle to our Milling category,
    as well as to your builder page: Mook's Homemade Tools. Your receipt:
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Here is a McMaster reference for the type clutch he used in this design.
    https://www.mcmaster.com/products/ro...ring-clutches/
    For those who are curious, he explained how this works on his Q&A in the yt post as such:
    Pressing the handle to the left can lightly lock the handle to allow the handle to retract the quill. A lot depends on your quill friction & spring pressure.
    For my machine. I increased the spring pressure to help with retracting the quill. I also added a spring loaded ball plunger adjacent to the handle thread to give a little constant friction. I will consider making a plastic split washer to give a finer adjustment to the housing friction onto the quill axle.
