Thread: Ball-joint workshop microscope stand
    New England, USA
    threesixesinarow's Tools
    This is a quick and crude stand I made to see whether smaller ball joints would be adequate to hold a beat-up old yard-sale stereo microscope. I planned to use it for a work light, but the test worked well enough that I never replaced it with something nicer. It’s compact and can work in cramped spaces.
    The arms are about 9” and 8”. The lower arm is made from a couple 3/32 x 3/4” steel straps, doubled around the ends and with a nylon spacer in the middle to help with clamping. The upper arm is a piece of 5/8 steel rod with balls at the the ends and turned down and bent to help positioning. All of the balls are 5/8” diameter, the lowest one with a 1/2”-13 threaded end and a couple flats on the shank to screw into a base. The ball sockets are just countersunk holes.
    From the combination of small balls and coarse threaded carriage bolt clamps it does need a wrench to set it up but then it will stay in place indefinitely, and can be repositioned without loosening anything.
    Ball-joint workshop microscope stand-ms01_onbench.jpg Ball-joint workshop microscope stand-ms02_onfloor.jpg
    Ball-joint workshop microscope stand-ms03_interface.jpg Ball-joint workshop microscope stand-ms04_turningtool.jpg
  2. The Following 6 Users Say Thank You to threesixesinarow For This Useful Post:
    Altair (Jun 6, 2019), Andyt (Jun 7, 2019), baja (Jun 7, 2019), Jon (Jun 13, 2019), Seedtick (Jun 6, 2019), Toolmaker51 (Jun 6, 2019)
    Thanks threesixesinarow! We've added your Microscope Stand to our Miscellaneous category,
