I think you picked the right side of threaded tube for it. right size for your hand too.eazy feed. and the automatic built in feature is oh so handy.if it starts feeding a little fast just add a little drag. you have done well grasshopper.
Frank S (May 24, 2024)
There is something else I can do with this machine that I haven't ever seen on other machines except for one that cost nearly 7K is I can run it in reverse by feeding all the way in turning my cutter over reversing the polarity then feed out while cutting.
One of the local farmers saw it when he picked up some pins I made for him, told me he wants to schedule some of his folding ag equipment to be worked on this winter after harvest the rota-hoe he has is 60 feet wide when in the field, folds up to 28 feet for transport the pivots are worn so I will bore them out and make or buy hardened sleeve bearings for it
marksbug (May 24, 2024)
