Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
Thread: Belt sander
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Nice work ..
    Sorry my mistakes in english.
  2. #12
    Supporting Member hardtail69's Avatar
    Jan 2015
    wilmington NC.
    hardtail69's Tools
    Quote Originally Posted by Captainleeward View Post
    OOOOO Yes I like it toooo. :O) Good Job.
    coming from you that is a quite a compliment. thanks
    hardtail
  3. #13
    Jan 2015
    wilmington NC.
    hardtail69's Tools
    ok quick update. as i said i don't have access to a lathe so i made all the rollers with straight D.O.M.tubing, but i really wanted to put a crown on the adjustment roller to help with the tracking. Well i figured out how to do that, even though i don't have a lath. I used an angle grinder. if you hold the angle grinder tangentially to the roller is will not only spin the roller at a nice rate it will also grind off material. So i did it. I put a nice crown on the roller and it is now tracking is even easier and is much less prone to running into the side of my sander if I press too hard on one side or the other. Just a tip I thought i should share.
  4. #14
    Good tip on that angle grinder, hardtail69.
  5. #15
    Oct 2014
    Coronado, CA
    Every once in a while, my ignorance presents it's self.
    Please inform me just what is D.O.M. tubing.
  6. #16
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Drawn Over Mandrel = thin-wall tubing
    It's a reference to the means of production.
    Ken
  7. The Following User Says Thank You to kbalch For This Useful Post:
    Nadogail (Mar 6, 2015)
  8. #17
    Mar 2015
    Awesome belt sander!
  9. #18
    Nov 2014
    Thanks Hardtail, that is one very solid looking build - not too complicated either. I have the need to build a belt sander and have looked at many on the internet; your's is the 1st one to "flop my mop". I don't have a welder but this sander looks to be build-able without welding. I notice you have drawn some plans and are offering them to us. Please include me when you send the plans out and I'll try to adapt them to non-weld construction. If successful I'll draw the no-weld variety for free distribution.
    RustyWrench email: stevegouldstevegould@hotmail.com
  10. #19
    Oct 2014
    Coronado, CA
    Thanks, you have added to my knowledge base.
  11. #20
    Mar 2015
    Boone, NC
    Hardtail,
    Good job.
    Are the DOM tubes covered with a rubber cushion material or is the belt running on metal tubes? Also is there a solid platen behind the belt? I'm considering building a taller version running a 106" belt for wet sanding glass. It's good to see how you made yours. I like the simple belt adjustment you devised.
