Results 1 to 10 of 12
Thread: Bench drill with cross feed, morse attaching?
    Supporting Member TexBuxer's Avatar
    Nov 2015
    TexBuxer's Tools
    I have old big bench drill and some milling bits. How can I make sure that bit holder stays in place. It has morse cone 2 or 3, and drill chuck drops when adding sideways pressure. I would't like to make permanent modifications.
    Edit, so it seem wise not to mill with it. But sometimes there is urgent need to make some tool/part.
  2. #2
    Supporting Member gunsgt1863's Avatar
    Oct 2013
    SE Wisconsin
    Check this video, I think this is what you are asking. WARNING, he uses some "colorful" language sometimes, but he is hilarious.
  3. #3
    Dec 2016
    I ran a horizontal boring, drilling, and milling machine with a tapered chuck and had a 6 inch diam. spindle and ran 12 inch carbide and high speed steel. Never had a spindle come loose. Some times even inserted a second tapered spindle inside the large.
    That being said. They are made to hold but the operator or machine maintenance is responsible to keep both the tapered holder and the spindle clean. Start by cleaning with steel wool and make sure there are no spots of rust or visible damage (flat spots or bumps)clean the inside of the spindle with the same vigor. When you are sure it is perfect, do it one more time. Make sure to wash the parts inside and out with a strong cleaner and wipe dry.
    Now place the tapered chick in the spindle and press the spindle down against a hard wood block onto the drill press table. Do this several times. Once you are sure it is in there tight, do it a couple more times. Those taper chucks are precision ground to form a vacuum that is very strong. If your chuck comes loose after that you need a new chuck or time to consider a new drill press. A drill press can and should hold. Small light milling taking light cuts should be ok. All of this depends on a good bond on the spindle and a smooth feed of the material. Common sense should always be used. Also if the spindle or chuck wobbles or chatters. Stop and see what is causing it. Chatter can cause even a good spindle come loose.
  4. The Following 3 Users Say Thank You to Big Mike71 For This Useful Post:
    Frank S (Aug 21, 2017), NortonDommi (Aug 22, 2017), Toolmaker51 (Jun 15, 2017)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Tapers Dimensions
    I cancelled what I'd written after a think. The guy above has no clue what he is doing! Did anyone else see the tool flex with his 'jerk' table feed style? These sort of posts are dangerous! About the only useable information is pointing out that there are tanged and open shanks. The "chowdery deposits" on the shank tell the storey of a dirty quill, a absolute no-no.
    About all I would attempt to mill with a drill is wood and maybe some plastics in an emergency and I will cop to having done so with anxious trepidation.
    Tapers have to be clean and burr free to work. Thin card wrapped around a shank and worked gently around can clean the female. Burrs can be stoned off a male shank. Most inportant is that the tapers are the same! I have seen a Morse,(not Morris as above),taper used? in a Brown & Sharpe taper by brute force and ignorance.
    Buy a Mill/Drill even a benchtop model can do a huge variety of work. Drills are for drilling at which they are wonderful. Attached is some of the most common tapers.
    Attachment 18087
  6. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    Frank S (Aug 21, 2017), Toolmaker51 (Jun 15, 2017)
    Jul 2014
    NortonDommi's Tools
    Wasn't refering to you Big Mike 71.
    Dec 2016
    I was sure you was not. Thanks for that. My problem with most posts are that the details are so lacking that it leaves to much room for answers on both sides. The best part of my answer is "common sense". For information the machine I ran was a Giddings and Lewis horizontal boring, drilling and milling machine costing more than a million dollars, a lot more. It could machine far beyond belief but small parts as you might put on a bench drill press. All possible because of a huge range of speed and feed changes. I machined parts weighing hundreds of tons and believe me, A hot Saturday morning Government job on a flat piece of steel weighing 20 Lbs. because I had my machine ready for set up at the time, Some of the workers came by and took pictures as it was funny. Any way without knowing what "tool' or material, it is impossible to give the man any good advice. I do some light and I do mean light milling on my drill press but I think my experiences and common sense through the years give me a little edge up. I have done many things in machining that I would never suggest others do and yes I would do them any time. Lets just hope we gave the man some insight and hope he makes the right and safe decision.
  9. The Following 2 Users Say Thank You to Big Mike71 For This Useful Post:
    NortonDommi (May 25, 2017), Toolmaker51 (Jun 15, 2017)
  10. #7
    Jul 2014
    NortonDommi's Tools
    Big Mike 71,
    I hear you. I had initialy written to TexBuxer on what to check and look for then had second thoughts. Then I watched that U-Tube
    TexBuxer I hope you read the replies as nobody would want an accident to befall you. I'm sure that copious doses of common sense will help.
  11. The Following User Says Thank You to NortonDommi For This Useful Post:
    Big Mike71 (May 26, 2017)
  12. #8
    Nov 2015
    TexBuxer's Tools
    Thanks for replys. I'm looking for cheap mill, I'm not going to waste more time for this.
  13. #9
    12L14's Avatar
    Aug 2017
    12L14's Tools
    1. http://framer99.blogspot.com/2012/11/diy-reverse-drawbar.html
    2. https://www.scribd.com/doc/269706198/How-to-Mill-on-a-Drill-Press
    3. http://www.homemadetools.net/forum/converting-drill-press-mill-drill-7870
    and the best solution:
    4. "it seem wise not to mill with it(...)I'm not going to waste more time for this"
  14. #10
    California, central coast
    C-Bag's Tools
    Quote Originally Posted by TexBuxer View Post
    Good job. Been there, experienced that. Ended up with an old cheap warhorse RF30 mill drill. Paid $400 with heavy duty table and while there are similar for many times that much(probably in way better shape) I believe it's possible for others with patience to find. Yeah, it's NOT the greatest but it's proven to be useful and has stood the test of time as there are still parts available through Grizzly.
    I also want to commend the others in their measured responses. We DONT want to discourage folks, and on other sites you could have gotten quite the lambasting. This topic of trying to make a drill press into a mill comes up regularly and there are some instances where they have turned the drill press into a mill, but good grief, the amount of work expended and $$ put into it would seem to not be cost effective. But hey, we all have our obsessions and who am I to judge?
    But when there is safety involved there is a line that has been crossed and some of us feel the need to speak up. It would seem TexBuxer came to the same conclusion on his own, so I'm not trying to belabor the point to him. My hope is that digital tide of lurkers get it too. Kids don't waste your time trying to do this at home
  15. The Following User Says Thank You to C-Bag For This Useful Post:
