Results 1 to 5 of 5
Thread: Bench Grinder: Angle setting gauge for tool rests
    Oct 2019
    Germany
    uv8452's Tools
    When working on a small machine like the TAIG Micro Lathe it is important to keep the cutting forces small; and to keep the tool bits sharp. That means frequent re-sharpening without wasting tool bit substance. The set angles of the tool rest need to ‚stay’ so that a shallow ‚shave’ is sufficient to remove the growing radius on the cutting edge. A second advantage of being able to adjust repeatably the grinding angle is to work with proven parameters - all the more important with small machines.
    As I didn’t find (and never saw) a gauge or method to adjust the angle of tool rests I built a small gadget which allowed exactly that. Here I’m offering you the basics - perhaps to build your own gadget.
    HMT GRINDER fin.pdf
    HMT GRINDER fin.pdf
    Your comments and improvements are welcome.
    Please tell me if I was too detailed.
    Thank you
    Ulrich
  2. The Following 7 Users Say Thank You to uv8452 For This Useful Post:
    DIYSwede (Jun 15, 2021), elk-a-holic (Jun 15, 2021), emu roo (Dec 29, 2025), Floradawg (Jun 16, 2021), Jon (Jun 15, 2021), Skun Knuckles (Jun 16, 2021), Toolmaker51 (Jun 15, 2021)
