Thread: Bench Grinder Upgrades
    Supporting Member Dr.Al's Avatar
    Jul 2018
    Dr.Al's Tools
    As the title implies, this isn't a home-made tool as such, just some modifications to a shop-bought tool:
    The updates I've made (which are described in exhaustive detail on a series of pages on my website) are:
    • I 3D-printed a new mount for the Tormek support arm so that it can be used on either wheel.
    • I made a new "universal support" that sticks out both sides so I don't have to flip the support back and forth. As the two wheels are the same diameter (and, being CBN, will stay the same diameter), I can set up a Tormek jig for the coarse wheel and then switch to the fine wheel without changing anything.
    • I made a speed nut (the brass nut you can see in the picture above) to make it quicker to move the nut around on the shaft - credit to This Old Tony for the idea.
    • I added a CBN wheel to the left-hand side (with some home-made bushes) to replace the original aluminium oxide wheel.
    • I added some rivnuts and replaced the Phillips screws with cap screws to make it quick and easy to get the covers off.
    Some excerpt photos from the build description:
    Bushes:
    3D-printed mount:
    Welding the new support bar (credit to This Old Tony for the jig idea):
    Drilling through the home-made nut to allow it to slide (at an angle) quickly along the bar (an idea that came from a This Old Tony video):
    I used a 3D-printed jig to hold the nut in the milling machine vice. That's not something I've ever tried before and I was a bit nervous about whether it would hold well enough, but it worked just fine. I'm not sure I'd want to use it for a heavy milling operation, but for a wonky drilling job it was perfect.
    Metalworking projects site: https://www.cgtk.co.uk/metalwork
    Woodworking projects site: https://www.cgtk.co.uk/woodwork
  2. The Following 6 Users Say Thank You to Dr.Al For This Useful Post:
    bruce.desertrat (Oct 25, 2025), butlerandrew (Oct 30, 2025), emu roo (Nov 3, 2025), Jon (Nov 1, 2025), PJs (Oct 27, 2025), rlm98253 (Nov 3, 2025)
    Thanks Dr.Al! We've added your Bench Grinder Modifications to our Grinding category,
    as well as to your builder page: Dr.Al's Homemade Tools. Your receipt:
    emu roo (Oct 25, 2025), Improvised DIY (Oct 31, 2025)
