Results 1 to 5 of 5
Thread: Thin-Walled Heat Glue Potting
Hybrid View
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    A thin layer of heat glue serves as an excellent potting material in low-voltage applications that will not be exposed to high heat. Here is how I make very thin strips of heat glue that I use for potting items like wire splices, especially when I forget to slide on shrink tubing first.
    If you are interested, click here.
    I welcome your comments and suggestions. All of us are smarter than any one of us.
    Rick
    Rick
  2. The Following 9 Users Say Thank You to rgsparber For This Useful Post:
    davesrepair (Oct 20, 2025), DIYer (Oct 17, 2025), emu roo (Oct 17, 2025), Floradawg (Oct 19, 2025), Inner (Oct 20, 2025), Jon (Nov 5, 2025), mwmkravchenko (Oct 17, 2025), PJs (Oct 20, 2025), thevillageinn (Oct 19, 2025)
    Great idea, Rick. Could have used this just a week ago, splicing in a replacement 12v power supply with very short leads.
    Thanks!
  4. The Following User Says Thank You to rebuilder1954 For This Useful Post:
    Perth Ontario Canada
    Saved Rick. I also use hot glue under normal heat shrink to make water proof connections. Sometimes I don't have hot melt adhesive lined heat shrink in the correct size. That's my extension cord trick!
    Mark
  6. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Hot glue can be used as splice insulation using a mold that encases the joint. These are available for purchase but can be machined from aluminium using a milling device. I have found that the mold can be safely gripped in a vice prior to injecting the hot glue as long as there is insulation to prevent the mold from cooling too fast.
