Results 1 to 10 of 10
Thread: Bench vise mounted metal bender
    Dec 2016
    bobs409's Tools
    I found video's for this little bench vice mounted metal bender on you tube and the plans are available online at the bottom of this page: http://oxtool.blogspot.com/2012/08/ so I just had to make one! I was planning on making some custom shaped peg hooks to fit odd shaped items and this is just the tool for the job. This thing works GREAT! It bends material effortlessly.
    I made a few changes to suit what materials I had on hand but stuck to the main idea. Some additions I made are some various sized die sleeves that slip over the 3/8 pin to create different radius curves. I also built an adjustable block that slips in the 2 holes and has a pivot pin that slides up close to the bending die. This is useful for making small bends on the ends of things like peg hooks and helps to avoid the waste you get from having the pins far apart.
    This can be used to bend various metals such as round, square and flat stock. Lots of great uses!
  2. The Following 23 Users Say Thank You to bobs409 For This Useful Post:
    Andyt (Apr 6, 2018), baja (Dec 13, 2019), blkadder (Dec 12, 2019), Carlos B (Jun 8, 2017), clydeman (May 8, 2025), Jon (Oct 3, 2019), LMMasterMariner (Jun 12, 2017), Marc Broussard (Jun 11, 2017), Moby Duck (Jun 9, 2017), mr mikey (May 8, 2025), NortonDommi (Jun 9, 2017), olderdan (Jun 9, 2017), old_toolmaker (Oct 9, 2023), pagespatchWELDING (Nov 3, 2017), Paul Jones (Jun 12, 2017), philippacificnw (May 8, 2025), PJs (Apr 6, 2018), rlm98253 (Apr 5, 2018), rossbotics (Jun 9, 2017), rudy3rd (Jun 11, 2017), saguaro (May 9, 2025), Toolmaker51 (Apr 8, 2018), Tuomas (Jun 9, 2017)
    Supporting Member Carlos B's Avatar
    Canada
    Carlos B's Tools
    Nice job. Great looking little bender.
    From a popular rap: "If time is money then I need a loan."
    Carlos B,http://hobbyworkshopprojects.blogspot.com
  4. The Following User Says Thank You to Carlos B For This Useful Post:
    bobs409 (Jun 9, 2017)
    Jyväskylä Finland
    Tuomas's Tools
    Thanks. Just what i needed.
  6. The Following User Says Thank You to Tuomas For This Useful Post:
    Thanks bobs409! We've added your Bender to our Metalworking category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
    Dec 2013
    Florida
    rossbotics's Tools
    I been needing to make something like that
    Comments are always welcome
    Doug
    Dec 2015
    Please supply link for the plans: I couldn't find them on the blogsite you posted?
  10. #7
    Dec 2016
    bobs409's Tools
    Hi, go to the bottom of this page:
    "Nothing Too Strong Ever Broke": August 2012
  11. #8
    Dec 2015
    Many Thanks - great project BTW!
  12. The Following User Says Thank You to pycoed For This Useful Post:
    bobs409 (Jun 12, 2017)
  13. #9
    thank you for the post of your bender If you would I could use any detailed plans you have building myself one of these for my shop thanks for your time
  14. The Following User Says Thank You to pagespatchWELDING For This Useful Post:
    davelack (Sep 20, 2020)
  15. #10
    Supporting Member high-side's Avatar
    Jun 2018
    Here are the prints.
    [ATTACH=CONFIG]3Bench vise mounted metal bender-table-8.jpg2540[/ATTACH]Bench vise mounted metal bender-center-pin.jpgBench vise mounted metal bender-clamp-plate.jpgBench vise mounted metal bender-fence-4.jpgBench vise mounted metal bender-pivot-arm-5.jpgBench vise mounted metal bender-pivot-boss-6.jpg
    Attached Thumbnails Attached Thumbnails Bench vise mounted metal bender-bronze-bushing.jpg
    Download plans for vises.
    Pat
  16. The Following User Says Thank You to high-side For This Useful Post:
    gapp63 (Jan 16, 2020)
