Is the bench peg a tool or a feature? Either way, I felt I could improve upon the design of mine to better suit my needs! :D
So, there's a video of it!
https://youtu.be/bM1kGwolM_A
Thanks SculptyWorks! We've added your Bench Peg to our Woodworking category,
as well as to your builder page: SculptyWorks's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-bench-peg-2"> <img src="/uploads/258719/homemade-bench-peg-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-bench-peg-2">Bench Peg</a> <span> by <a href="https://www.homemadetools.net/builder/SculptyWorks">SculptyWorks</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/workbench'>workbench</a> </div> </div> </div> </div>
It doesn't look like your V-notch intersects the vacuum connection. If not, I'd drill a hole near the bottom of the V-notch to connect them. You could use a sheet plastic or metal gate to laid over the large hole in the end to increase draw at the V-notch, or a smaller gate to block it off so the larger hole draws air better, and make it even more versatile.
For cheap bastriches like me, it could be built as a pine box from scraps so you could avoid using a nice piece of solid cherry wood... ;) Would make cutting the holes a bit easier, too.
Bill
