Results 1 to 7 of 7
Thread: Blacksmith Gas Forge from old Gas Tank
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    Lightbulb Blacksmith Gas Forge from old Gas Tank
    Finally my burner has found its home in the form of a Blacksmithing Propane Forge
    The forge is built using a homemade Frosty T-Burner from this post:
  2. The Following 3 Users Say Thank You to Mazay For This Useful Post:
    Jon (Jan 31, 2025), sossol (Jan 7, 2025), tuchie (Jan 11, 2025)
    Thanks Mazay! We've added your Forge to our Forging and Casting category,
    as well as to your builder page: Mazay's Homemade Tools. Your receipt:
    tags: forge
    Piros1
    Dittmer, MO
    What size mug welding tip did you use?
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    Quote Originally Posted by Piros1 View Post
    MIG Welder Contact Tip D=0.8mm M8
    Piros1, other parts of the burner you can see in the drawings, you can download for free here - https://mazaydiy.com/frosty-t-propane-forge-burner/
    Do you use an anti-flashback valve in the propane line?
    Mazay's Avatar
    Jul 2019
    Mazay's Tools
    No. But yes, I have heard about anti-flashback valves and I am not entirely sure if it is necessary to install them in my burner, although people have been working on such burners for years (without anti-flashback valves).
    I am not a pro in these matters, but I have read that they need to be installed only if there is a pre-mixing of the combustible mixture and oxygen. There is no pre-mixing in the T-Frosty burner.
    There is no pre-mixing on a cooking gas stove either, and I have not heard that it is recommended to install anti-flashback valves on them.
    If you or someone else is more knowledgeable on this issue, I would be happy to hear the opinion of a professional.
  8. #7
    I am not a professional in these matters and I have used oxy-acetylene welding and cutting torches without flashback protectors. However, that was before I knew about them or the potential danger.
    You make a good point about a cooking stove and I am sure that the risk with your burner is low.
    Download plans for forging and casting tools.
