7 Attachment(s)
Bolt Modification Fixture
If you ever needed a dog point screw, a pointed set screw, or even just a flat end screw
then this is a handy adapter that can get the job done in a 3 jaw chuck.
Make up several Screw Bushings before tapping the 10-32 set screw holes.
Use the housing as a drilling guide for all the bushings before tapping the set screw holes.
The bushing should be a slip fit into the Housing for best operation.
1/2-20 Bolt and Nut may either be turned round and knurled or just drill the hex heads
for a .187 Tommy bar. They can even be left as is and just use a wrench. Very light pressure
so you do not push hard on the Screw Bushing.
I leave drilling /reaming the Screw Bushings until I know what size screw it will be used for.
I used another accessory to flatten the end of the 1/2-20 bolt. I needed a true surface on
the end of the bolt and did not want it dished. Here is the link to the build thread for that tool.
https://www.homemadetools.net/forum/...171#post244545
And yet another Bolt modification tool. The Lantern Chuck.
https://www.homemadetools.net/forum/...318#post103946
