If you want to sleeve it, then Sintered Bronze is the way to go. If possible buy the sleeve in a size to fit your steel shaft, and avoid reaming the internal diameter. Buy pre-impregnated with oil, or impregnate under a vacuum, and you should never have to oil it again.
