Thread: C/Bores from old end mills
    As I spent much of my time in the grinding shop I used to make piloted counter bore cutters from old end mills for our jig borer, ok I had access to a universal grinder at the time but I have since made them by off hand grinding and finishing with a toolpost grinder and a home made Dremel type tool for backing them off. There is no great precision required in making this type of cutter after all you are only getting a cap head out of the way. Being HSS they last well and can be touched up with a diamond file. Also easy to make from drill rod in a two lip style.
    Here is a pic of the ones I am using at the moment, I have a large box of old end mills etc so I make them up as needed.
    C/Bores from old end mills-imgp0006.jpg
  2. The Following 24 Users Say Thank You to olderdan For This Useful Post:
    Andyt (Sep 25, 2020), Canyonman44 (Aug 3, 2021), emu roo (Jul 29, 2025), Frank S (Sep 7, 2018), high-side (Sep 26, 2020), Home-PC (Dec 28, 2018), jjr2001 (Oct 6, 2018), johncg (May 26, 2022), johnsmachines (Jul 6, 2023), Jon (Sep 7, 2018), Ken Koch (Dec 28, 2018), mwmkravchenko (Sep 7, 2018), nova_robotics (Sep 24, 2020), Okapi (Sep 8, 2018), old_toolmaker (Sep 24, 2020), Paul Jones (Sep 11, 2018), PJs (Sep 10, 2018), Ralphxyz (Mar 9, 2025), Seedtick (Sep 7, 2018), tonyfoale (Dec 27, 2018), Tonyg (Sep 8, 2018), Toolmaker51 (Sep 14, 2018), tooly (May 25, 2022), Tule (Dec 28, 2018)
    Mar 2013
    Switzerland
    Okapi's Tools
    A good idea for recycling, and very useful if you like to use hidden heads!
    I'm a Ifanger counterbore mills fan and they are very expensive if you want them new, a good alternative.
  4. The Following 2 Users Say Thank You to Okapi For This Useful Post:
    emu roo (Jul 29, 2025), olderdan (Sep 8, 2018)
    Howder1951's Avatar
    Jan 2016
    In the machine shop at work, we had one fellow who would turn down the end of a partially softened drill bit to make a specialized counterbore with carbide or ceramic tooling, similar to this approach. Nice post!
  6. The Following User Says Thank You to Howder1951 For This Useful Post:
    I've made a lot of counter bores out of drill bits on my lathes with tool post grinders then touched up the cut angle manually on a bench grinder
  8. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Jul 29, 2025), johnsmachines (Jul 6, 2023), olderdan (Sep 8, 2018), Paul Jones (Sep 13, 2018)
    Thanks olderdan! We've added your Counterbore Cutters to our Machining category,
    as well as to your builder page: olderdan's Homemade Tools. Your receipt:
    Download plans for boring heads.
  10. The Following User Says Thank You to DIYer For This Useful Post:
