Results 1 to 8 of 8
Thread: Can anybody tell me what this is for?
Hybrid View
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi Moby Duck,
    It is angle grinder base (for 115~125mm models),
    for convert and use them like a chop saw.
    I have one similar but I have use it, only two times.
    The correct setup it's pain and fiddly each time that you will need it,
    and if you haven't a second angle grinder to burying on it,
    I would not recommend you buying it.
    Regards
    Bill
  2. The Following User Says Thank You to kess For This Useful Post:
    Moby Duck (Mar 1, 2016)
    Jan 2016
    Moby Duck's Tools
    Thank you Kess, your advice is appreciated and as it has missing parts I will be taking your advice and will not buy it.
    Thanks to everybody that has helped me identify this.
    My problem is solved.
    Case closed.
