Results 1 to 4 of 4
Thread: Casting brake shoes - GIF
    Altair's Avatar
    nova_robotics (Aug 19, 2023), piper184 (Aug 14, 2023)
    Aug 2012
    Australia
    desbromilow's Tools
    what is happening? the video isn't clear - does anyone have the extended source video?
    thanks,
    Des
    Quote Originally Posted by desbromilow View Post
    thanks,
    Des
    What is going on in the video, is they are placing moped or motor scooter brake shoe castings into the mold then filling it with the powdered friction material the piece of white material is there to keep the friction material from bonding to the press die. Under high enough pressure the powder becomes solid forming the friction part of the brake shoes. This process is much the same as cutting inserts and pressed metal parts such as gears and couplers are made.
  5. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    Altair (Sep 8, 2023), WorkerB (Aug 17, 2023)
    Aug 2012
    Australia
    desbromilow's Tools
    Thanks Frank,
    I suspected that was the case, but I had it in my head that the friction media was thermoset resin based, not pressure consolidated material. I guess the same pressure consolidation which makes the friction material stick to itself, also makes it stick to the castings.
    Thanks,
    Des
  7. The Following User Says Thank You to desbromilow For This Useful Post:
    Frank S (Aug 14, 2023)
