Thread: Casting concrete cube for crush testing - GIF
    May 2024
    nova_robotics (Nov 4, 2024)
    Marion, Iowa
    metric_taper's Tools
    All I've ever seen for certification test of concrete (here in the USA), cardboard helical wound forms are used. I think they are 6" diameter, and match the test machine hydraulic foot and anvil.
    I can see that a larger test specimen might give better numbers, if someone is messing with the ratio of materials.
    It does appear they are pouring a mono-pour foundation footing with thick slab of some sort.
  4. The Following User Says Thank You to metric_taper For This Useful Post:
    Sep 2018
    nova_robotics's Tools
    I've never seen this either. We always do 4" diameter cylinders in those gray plastic tubes with the caps on them. Can't say I've ever seen a concrete test fish tank before.
