11 Attachment(s)
Center Punch Guide
I built this little tool to assist in holding a center punch at 90° from the work surface; it’s hard to hold a center punch at perfect right angles, when you strike the punch and it’s not held at 90° then it will move creating an inaccurate center punch mark, this tool eliminates that problem.
This tool was designed to be simple and user friendly; the punch guide is a one piece construction which was made from 1018 CRS, with a .500” reamed hole thru the entire length of the tool to guide the punch accurately, while the punch itself was made from O-1 tool steel hardened and tempered ¾” on each end.
The guide was designed to work on either a flat or round surface, it has a two inch wide 90° crotch in the center of the body that will locate itself on a round surface (a shaft, pipe etc) plus the crotch also acts a viewer when locating a scribe mark on a flat surface, it has a ½” viewing hole in each of the legs which makes it very easy to locate scribe marks on a flat surface.
The punch was made from a piece of .500” Round by 5 ¼” Long O-1 tool steel hardened and tempered ¾” on each end, the end of the punch is machined at a 60° angle and a steep 14° angle from the end of the 60° point which gives allot of clearance for viewing and locating the point on your work piece.
Below you will see some photos of the machining process along with the tool being used on a flat and round surface; I have also included drawings for anyone who wants to make one of these tools.
As always thanks for looking
And happy machining
Doug
Attachment 18918
Finished punch
Attachment 18919
Drawings
Attachment 18920
How it was machined
Attachment 18921
Machining from an arbor
Attachment 18922
A view of completed punch assembly
Attachment 18923
Top view
Attachment 18924
Used on a round surface
Attachment 18925
Used on a flat surface
Attachment 18926
A center punch mark
Attachment 18927
Drawing 1
Attachment 18928
Drawing 2
This is again an excellent and very precisely done job as every other job you did and posted here. Thanks for sharing. The only observation is regarding tip angle of 60 degrees, which according to some people is not wide enough to guide drill bit to start hole right in the centre. I had that discussion several times with couple of very good machinists and engineers and most of them are claiming that center punch angle tip should be 90 degrees. I was using numerous fuel injector needles with different tip angle as center punches and I was very happy with all of them. But actually whenever I see original center punch, the tip angle is 90 degrees or very close to it.
Cheers
LMMM
Thanks rossbotics! We've added your Center Punch and Guide to our Measuring and Marking category,
as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-center-punch-and-guide">
<img src="/uploads/202388/homemade-center-punch-and-guide.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-center-punch-and-guide">Center Punch and Guide</a>
<span> by <a href="http://www.homemadetools.net/builder/rossbotics">rossbotics</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/punch'>punch</a>, <a href='http://www.homemadetools.net/tag/guide'>guide</a> </div>
</div>
</div>
</div>
Nice job Rossbotics, have you proof the same constuction with a 2-3X magnifier ?
Have a nice day.
Pierre
Thank you for compliment LMMM
The reason for the 60° point is for visual purposes, that little bit of angle difference greatly increases the visual of locating the point of the center punch, I have always used a small pilot drill of no more than 3/32" to start with, then open the hole in increments to the final size, I am very aware of the proper 90° for a common center punches, even the common hand held center punches I have also have a steeper angle than 90° for that visual purpose, I agree that if someone wanted started with a 1/2" bit would create a walking problem.
Thanks for bringing that up LMMM I should have mentioned the small pilot drill is necessary first then open up the hole in increments.
Cheers LMMM
First off good job I like it
I like the 60° point as well. I find that when punching intersecting scribe lines trying to locate the exact center of the intersection is near impossible with a standard ground center punch. for this reason my layout punches are ground to the steeper angle often as steep as 45° if I find I require a wider more definitive punch mark I can always re punch with a wider punch but a lot of times just use a 1/8 or 3/16" diameter center drill to enlarge the mark before drilling
regarding the punch angle, simply call it a "prick punch" rather than centre punch and the issues go away. in layouts, a prick punch is used to form the depression for the centre punch to follow in... easy.
I always first use a prick punch for my high precision layout, then verify the locations, and finally follow-up with a center punch.
I have an old LS Sterrett automatic center punch that was among some other tools I bought at auction some years ago
Someone had reground the point on it so it was more of a scribe than a than a center punch or a prick punch it worked great for layout on SS or aluminum as well as mild steel but I have dulled the point and need to regrind it the next time I find it
I only rarely use punches for precision hole layout. I rely on the tool dials which are more accurate than any punching could be. On complex jobs I often do a layout on the workpiece to use as a guide to keep myself honest but the line intersections aren't punched; they're just there to warn me if I miscount dial rotations - the dreaded 0.1" location error.
For low precision stuff like wood and structural elements, I use punches. My favorite for wood is this one...
http://www.homemadetools.net/forum/p...9225#post54767
which keeps the punch from "following" the grain of the wood.
Congratulations rossbotics - your Center Punch and Guide is the Homemade Tool of the Week!
Some nice picks from this week: a Brake Turning Tool by darkoford, a Small Parts Finger Plate by Brendon, HF Crane Mounts by Viny, a Camera Stand by Serra Cabo, Pulley Removal Tools by TexBuxer, a Diamond Toolholder Adapter by rgsparber, and a HF Wire Twisting Pliers Modification by rgsparber.
rossbotics - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, Giftrocket, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
This is your 17th Tool of the Week win! Nobody has yet claimed the 25-Time Homemade Tool of the Week Award (all winners are viewable here); it's probably the most difficult award for DIYers to win on the net right now, but you're creeping up on it. At current pace, it looks like it's going to come into view in 2018 or 2019. Very interested to see what the future will bring.
Here are all of your 17 wins:
<div id="blocks">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/surface-gage-12175#post14591"><img src="/uploads/96960/height-and-square-gauge.jpeg" alt="Height and Square Gauge" /></a> </div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/surface-gage-12175#post14591">Height and Square Gauge</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div>
<div class="tags">
tags:
<a href="/tag/gauge">gauge</a>, <a href="/tag/square">square</a>, <a href="/tag/dial-indicator">dial indicator</a>, <a href="/tag/height-gauge">height gauge</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/filing-machine-12989#post15657"><img src="/uploads/100104/filing-machine-3.jpeg" alt="Filing Machine" /></a> </div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/filing-machine-12989#post15657">Filing Machine</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div>
<div class="tags">
tags:
<a href="/tag/file">file</a>, <a href="/tag/gunsmithing">gunsmithing</a>, <a href="/tag/motor">motor</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/slitting-saw-arbor-15838#post21004"><img src="/uploads/110216/slitting-saw-arbor-7.jpeg" alt="Slitting Saw Arbor" /></a> </div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/slitting-saw-arbor-15838#post21004">Slitting Saw Arbor</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div>
<div class="tags">
tags:
<a href="/tag/machining">machining</a>, <a href="/tag/arbor">arbor</a>, <a href="/tag/slitting-saw">slitting saw</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/threading-insert-tool-holder-16929#post22973"><img src="https://www.homemadetools.net/uploads/139555/threading-insert-tool-holder.png" alt="Threading Insert Tool Holder" /></a> </div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/threading-insert-tool-holder-16929#post22973">Threading Insert Tool Holder</a> <span> by <a href="/builder/rossbotics">rossbotics</a></span> </div>
<div class="tags">
tags:
<a href="/tag/lathe">lathe</a>, <a href="/tag/tool-holder">tool holder</a>, <a href="/tag/threading">threading</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/tool-makers-vise-18400#post25623"><img src="https://www.homemadetools.net/uploads/118802/toolmaker-s-vise-2.jpeg"
/></a></div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/tool-makers-vise-18400#post25623">Toolmaker's Vise</a>
</div>
<div class="tags">tags: <a href="https://www.homemadetools.net/tag/vise">vise</a>, <a href="https://www.homemadetools.net/tag/machining">machining</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/indexing-fixture-27750#post37609"><img src="https://www.homemadetools.net/uploads/129644/indexing-fixture-2.jpeg"
/></a></div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/indexing-fixture-27750#post37609">Indexing Fixture</a>
</div>
<div class="tags">tags: <a href="https://www.homemadetools.net/tag/gears">gears</a>, <a href="https://www.homemadetools.net/tag/indexing-unit">indexing unit</a>, <a href="https://www.homemadetools.net/tag/fixture">fixture</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/r-8-modular-gear-cutter-arbor-29332#post40078"><img src="https://www.homemadetools.net/uploads/132398/gear-cutter-arbor-2.png"
/></a></div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/r-8-modular-gear-cutter-arbor-29332#post40078">Gear Cutter Arbor</a>
</div>
<div class="tags">tags: <a href="https://www.homemadetools.net/tag/arbor">arbor</a>, <a href="https://www.homemadetools.net/tag/gears">gears</a>, <a href="https://www.homemadetools.net/tag/cutting-tool">cutting tool</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/direct-indexing-sharpening-fixture-31319#post43293"><img src="https://www.homemadetools.net/uploads/136090/direct-indexing-sharpening-fixture.jpeg"
/></a></div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/direct-indexing-sharpening-fixture-31319#post43293">Direct Indexing Sharpening Fixture</a>
</div>
<div class="tags">tags: <a href="https://www.homemadetools.net/tag/sharpening">sharpening</a>, <a href="https://www.homemadetools.net/tag/fixture">fixture</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/tool-post-grinder-33437#post46937"><img src="https://www.homemadetools.net/uploads/139267/tool-post-grinder-16.jpeg"
/></a></div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/tool-post-grinder-33437#post46937">Tool Post Grinder</a>
</div>
<div class="tags">tags: <a href="https://www.homemadetools.net/tag/grinder">grinder</a>, <a href="https://www.homemadetools.net/tag/pulley">pulley</a>, <a href="https://www.homemadetools.net/tag/tool-post">tool post</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/end-mill-sharpening-fixture-41232#post59042">
<img src="/uploads/146651/end-mill-sharpening-fixture-2.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/end-mill-sharpening-fixture-41232#post59042">End Mill Sharpening Fixture</a>
<span> by <a href="https://www.homemadetools.net/builder/rossbotics">rossbotics</a></span>
</div>
<a href='https://www.homemadetools.net/tag/sharpening">sharpening</a>, <a href='https://www.homemadetools.net/tag/fixture">fixture</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/machine-tool-dial-making-fixture-56086#post83022">
<img src="/uploads/163713/homemade-dial-making-fixture.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/machine-tool-dial-making-fixture-56086#post83022">Dial Making Fixture</a>
</div>
<a href='https://www.homemadetools.net/tag/fixture'>fixture</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/brass-shop-hammer-57046#post84922">
<img src="/uploads/164505/homemade-brass-hammer.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/brass-shop-hammer-57046#post84922">Brass Hammer</a>
</div>
<a href='https://www.homemadetools.net/tag/hammer'>hammer</a>, <a href='https://www.homemadetools.net/tag/machining'>machining</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/forum/universal-grinding-fixture-58728#post88008">
<img src="/uploads/166373/homemade-universal-grinding-fixture.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/forum/universal-grinding-fixture-58728#post88008">Universal Grinding Fixture</a>
</div>
<a href='https://www.homemadetools.net/tag/grinding'>grinding</a>, <a href='https://www.homemadetools.net/tag/fixture'>fixture</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-tilting-dividing-fixture">
<img src="/uploads/169201/homemade-tilting-dividing-fixture.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-tilting-dividing-fixture">Tilting Dividing Fixture</a>
</div>
<a href='https://www.homemadetools.net/tag/indexing-unit'>indexing unit</a>, <a href='https://www.homemadetools.net/tag/fixture'>fixture</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-dial-indicator-attachment">
<img src="https://www.homemadetools.net/uploads/169409/homemade-dial-indicator-attachment.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-dial-indicator-attachment">Dial Indicator Attachment</a>
</div>
<a href='https://www.homemadetools.net/tag/milling'>milling</a>, <a href='https://www.homemadetools.net/tag/dial-indicator'>dial indicator</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-shear-3">
<img src="/uploads/201577/homemade-shear-3.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-shear-3">Shear</a>
</div>
<a href='https://www.homemadetools.net/tag/shear'>shear</a> </div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-center-punch-and-guide">
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-center-punch-and-guide">Center Punch and Guide</a>
</div>
<a href='https://www.homemadetools.net/tag/punch'>punch</a>, <a href='https://www.homemadetools.net/tag/guide'>guide</a> </div>
</div>
</div>
</div>
Congratulations. Well deserved.
Great job and congratulations on another tool of the week. I'm planning on making one of these and your post is helpful.
Excellent tool!
Have you given any thought to adding a perspex viewing tube (with imbedded crosshairs) to more accurately position the center punch on the work - i.e. similar to the optical center punch at lee valley tools (VeritasĀ® Optical Center Punch - Lee Valley Tools) with its included 8-power monocular or the homemade version featured by knoba on hmt at (http://www.homemadetools.net/forum/o...81#post28636)? - or is this too fussy for your intended tool use?
As mklotz noted, truly accurate positioning requires dial gauges, but an optical viewing tube would improve hole placement quite a bit.
Gary (kngtek)
Calgary, AB
I don't use a center punch enough to even own one besides putting cross hairs in it LOL, this tool was built for the sole purpose of competing and making a tool to post in the home made tools forum, I doubt highly it will ever get struck by a hammer, I'll never use it, I use machine dials and DRO's for everything I do, I'll probably give it to my neighbor for a paper weight, it was just something I wanted to make and share, thanks for your comment.
Simple and brilliant tool. Thank you.
